Moose Flap handle
Robert and Olga Johnson
Moose Flap handle
Post by Robert and Olga Johnson » Sun Feb 19, 2012 11:12 am
During a recent visit from Bob P, it was suggested to move the flap handle back from the position indicated in the manual. It does appear to be to far forward causing you to have to lean forward to grasp, and also may cause leg interference between stick and flap handle during hard right aileron control with flaps partially actuated. If others have run into this problem and corrected, I would be interested in knowing how far back you moved the flap handle control. Thanks Bob J ( moose 226)
