Hi:
MAM states the lower engine mount holes are to be 23/32 " up from the
bottom of the firewall. When I place FUS 85 & 86 bolted together on the floor
on top of the .032 gusset I have 5/8 "- should I put a shim under the FUS
85/86 to bring it up to 3/4?? Thanks for the help.
Rebel engine mount
Rebel engine mount
Be sure to make the .032 gusset extra long so the rudder pedal blocks (left
side is longest) will set on it.
http://n254mr.com/gallery2/v/254R/Build ... S.JPG.html
I would skip the shim. It is best to have the mount on hand to match the
holes.
On 9/10/2006 8:18 AM, ken wrote to Murphy- Builders:
-> Hi:
-> MAM states the lower engine mount holes are to be 23/32 " up from the
-> bottom of the firewall. When I place FUS 85 & 86 bolted together on the
floor
-> on top of the .032 gusset I have 5/8 "- should I put a shim under the
FUS
-> 85/86 to bring it up to 3/4?? Thanks for the help.
-> Ken
holes.
-> Hi:
floor
FUS
-> Ken
