[rebel-builders] Rebel - Elevator Control Horn Alignment
Jeff McMurrer
Post by Jeff McMurrer » Sun Feb 19, 2012 11:08 am
Rich,
As for the two "extra" EL-26's, you will find that you will most likely use them for the elevator trim..... if you so elect to install one on your Rebel.
Jeff
I received 15 EL-26 elevator-rudder ribs in my kit. I used five
for the rudder. It looks like I am going to use four more for
each elevator. That leaves two. Are those spares? I really hate
it when there are parts on the workbench after I put something
together! Haha!
Thanks a bunch guys!
Rich
Rich Dodson
Post by Rich Dodson » Sun Feb 19, 2012 11:08 am
Thanks Jeff!
Do you know the answer to my previous question on the control horn alignment on the elevators? I have not gotten any answers from here or Murphy tech support.
All I need to know is how the control horn is aligned to the line made by the elevator's ribs. Does it hang down perpendicularly?
Thanks again.
N.Smith
Post by N.Smith » Sun Feb 19, 2012 11:08 am
Hi Rich
On the Elite it bolts onto the forward spar, and runs up and down 90 degrees
from the spar IE straight up and down from a horizontal elevator. I guess on
your type it may be different though.
Nig
745E
Rich Dodson
Sent: 08 September 2006 11:10
Subject: Re: [rebel-builders] Rebel - Elevator Control Horn Alignment
Thanks Jeff!
support.
Thanks again.
Jesse Jenks
Post by Jesse Jenks » Sun Feb 19, 2012 11:08 am
Yes, perpendicular.
Subject: RE: [rebel-builders] Rebel - Elevator Control Horn Alignment
Date: Fri, 8 Sep 2006 11:51:33 +0100
Hi Rich
degrees
on
Nig
745E
Rich Dodson
Thanks Jeff!
alignment
support.
Thanks again.
Rich Dodson
Thanks Jesse and Nigel...off to the airport tomorrow to do some more drillin'!
Rich
Rebel 806R
