What most do is insert an aluminum rivet of proper size in the line with
very small hole thru it so if the line breaks, u don't piss out all ur oil
before u have a chance to put ur ass on the ground safely.
Steve W.
From: "Jones, Michael" <Michael.Jones@snclavalin.com>
To: "Rebel-Builders (E-mail)" <rebel-builders@dcsol.com>
Subject: [rebel-builders] OIL PRESSURE GAGE Date: Mon, 28 Aug 2006 08:54:49
-0400
hi all
so in hooking up my oil pressure gage, the firewall forward book by tony
bingelis so to use a restrictor fitting at the engine, does anyone know
where i can get one of these, i see a primer restrictor fitting in spruce
that is brass fitting 1/8 x 5/16-32, is this what i should use
thanx
mike#007
