[rebel-builders] bulkhead F
Jesse Jenks
Post by Jesse Jenks » Sun Feb 19, 2012 11:00 am
Dave,
You need to bent the top flange of bulk. F down at an angle so it matches
the angle of the top of FUS 24. After doing that I set it's height slightly
above the top of FUS 24. I don't have the roof or the FUS 27s on yet, so I
can't say how will work. I did spend some time trying to figure out how to
locate the top of bulk. F, and then gave up and basically guessed.
Jesse
Subject: [rebel-builders] bulkhead F Date: Sat, 15 Jul 2006 08:11:06 -0400
Can anyone help with what seems to be confusion to me?
Is the height of bulkhead F, to be the same as the skin of fus 24 ? or does
it stick up just a little above that skin? No matter what I do here it just
doesn't look quite right.
Thank you
Dave T./ rebel 009
