[rebel-builders] Rebel elevator trim
Post by Ken » Sun Feb 19, 2012 11:00 am
Hi Brian
I had an unexpected opportunity to fly this morning and I ran the trim
to the stops. An inch or 1.25" of deflection is fairly easy to overpower
if it were to fail at that deflection. I concluded that I'd likely never
use an inch of up deflection (nose down trim). Tooling around at very
low power and speed I can see using an inch or maybe even a bit more of
down deflection (nose up trim). As other guys have said there is really
no need to change the trim in the circuit. The trim rate or speed was
just fine with the push rod in the outer hole of the trim tab horn.
Brian Breathnach wrote:
Greetings to all
Just about to cut the elevator trim push rod to length.
Before I take the hacksaw to her I figured I would check see if there is a minimum up/down trim deflection that is in common use.
Seems to me that the trim deflection Im getting is not all that much
--maybe an inch or so give or take a bit--when measured from the neutral position.
All comments welcome.
Brian
R779
Brian Breathnach
Post by Brian Breathnach » Sun Feb 19, 2012 11:00 am
Thanx Ken,
Good to know the 1" up/down trim deflection is in the right range.
Enjoy the 1000 foot up/down circuit deflection in your new bird and keep the
blue side up. Where do you do your flying from??
Brian
Sent: Thursday, July 13, 2006 9:12 AM
Subject: Re: [rebel-builders] Rebel elevator trim
Hi Brian
Greetings to all
position.
Brian
R779
