Rebel elevator trim
Brian Breathnach
Rebel elevator trim
Post by Brian Breathnach » Sun Feb 19, 2012 11:00 am
Greetings to all
Just about to cut the elevator trim push rod to length.
Before I take the hacksaw to her I figured I would check see if there is a minimum up/down trim deflection that is in common use.
Seems to me that the trim deflection Im getting is not all that much
--maybe an inch or so give or take a bit--when measured from the neutral position.
All comments welcome.
Brian
R779
