[rebel-builders] air filters
Post by Mike Davis » Sun Feb 19, 2012 11:00 am
I'm pretty sure Ralph Baker used a K&N on his Elite... you still out there
Ralph?
From: "Jones, Michael" <Michael.Jones@snclavalin.com>
To: "Rebel-Builders (E-mail)" <rebel-builders@dcsol.com>
Sent: Monday, July 10, 2006 10:19 AM
Subject: [rebel-builders] air filters
hi all
does no body know a k & n part number to replace the reel stock foam
filter
mike#007
Dave Ricker
Post by Dave Ricker » Sun Feb 19, 2012 11:00 am
Hi Guys
I'll pipe up here for Ralph as I think he's away on a road trip for a while.
If I remember correctly Ralph & Sue have an RV air box so it might not be the
same setup as you (Mike J) are thinking about. The photo I took when I
visited this spring does show a K & N sticker so you are correct about that
part.
Don't know if this moves us any further forward but.......there it is!
Ralph?
hi all
filter
mike#007
David A. Ricker
Fall River, Nova Scotia
Canada
Post by Drew Dalgleish » Sun Feb 19, 2012 11:00 am
I'm curious what's wrong with the stock foam filter?
At 10:29 PM 7/10/2006 -0300, you wrote:
Hi Guys
part.
Ralph?
hi all
filter
mike#007
David A. Ricker
Canada
Rebflyer
Post by Rebflyer » Sun Feb 19, 2012 11:00 am
Hi Mike,
I don't have the number handy, but Challenger aircraft is making them. I
think the Rebel is the same as a C-150 filter, made by Brackett.
I think I posted on this once before, it might be in the archives. I'll
try and remember to dig it out of my logs today.
In answer to the question of why are they better, I got 75-100 rpm on
static just by changing the filter. It might just be my setup, but I think the
0-320 needs the better airflow that the K+N provides. And they last forever.
Just clean and reoil.
IMHO
Curt N97MR
Jones, Michael
Post by Jones, Michael » Sun Feb 19, 2012 11:00 am
hi curt
i searched archives last night and could not find a number, found some stuff
but no number, would be great if you could dig it up,
thanx
mike#007
Rebflyer@aol.com
Sent: Tuesday, July 11, 2006 7:36 AM
Subject: Re: [rebel-builders] air filters
Hi Mike,
forever.
IMHO
Curt N97MR
Dale Fultz
Post by Dale Fultz » Sun Feb 19, 2012 11:00 am
I just had to add my opinion on the K & N filter,, they don't last forever
if they are cleaned once they are not as efficient as they were when new.
Does anyone know what happens to paper when it gets wet? Same thing with the
K&N if you look at independent reports and not K&N reports on it you will
find they are not the answer.
Just thought I would add my two cents.
Dale
SR-033
eric.r
Post by eric.r » Sun Feb 19, 2012 11:00 am
Nothing lasts forever, and horsepower requires $$$. After years of using K&N
on race cars and race motorcycles, I can assure you that they do make
power over alternative filters. BUT, if they are abused (get wet) I would
consider replacing it with new. Air filters were never designed to run in water,
so every time you ingest the liquid, replace the filter! On the race vehicles
that ran on wet dirt tracks, we used a foam cover over the filter to stop the
big chunks of wet mud ... maybe a good call when flying in the rain?
On 7/11/2006 4:26 AM, dfultz17086@earthlink.net wrote to rebel-builders:
-> I just had to add my opinion on the K & N filter,, they don't last forever
-> if they are cleaned once they are not as efficient as they were when new.
-> Does anyone know what happens to paper when it gets wet? Same thing
with the
-> K&N if you look at independent reports and not K&N reports on it you will
-> find they are not the answer.
-> Just thought I would add my two cents.
-> Dale
-> SR-033
Dale Fultz
I am by no means an expert on this subject, (so please don't have anyone get
mad for my writings) I am only trying to pass along my own experience with
airfilters,,,Check out this link for one business that used K & N
http://rds.yahoo.com/_ylt=A0Je5rk9y7NE3 ... omparisons
I can give you numerous test done by independent people, I have nothing
against K & N but I too am in the racing world, and I realize 800 HP on dirt
is different then in an airplane. Been in dirt racing for a long time K &
N certainly doesn't filter like their test show they do. Since switching
filters we run an entire year without engine problems. All I am trying to
say is just because they aren't afraid to charge for there filters doesn't
make them good, some of the people that advertise for them get paid, some
get paid and don't run them. There is alternatives out there please do your
own research with the amount of money you have in your engines. I am done
now on this subject ... Dale SR-033
Thanks Guys I guess they're probably also a bad idea on a floatplane.
water,
vehicles
forever
with the
Dale
-> SR-033
Dale Fultz
Hi Drew, Actually the air filters are multi layers of cotton, (not paper) of
different textures or weave as some call it. Well the problems start when
cotton gets wet it shrinks sometimes as a cotton shirt does. The layers
don't conform to original because the different weaves shrink at a different
rate then the other layers and that's when the problems start.
The technology has really advanced with the foam filters, if on
floats I would really look into them, as an all around filter.
There is a lot more finer details to the cotton filters but that is
kinda a condenced version of the research we have found with them. Hoper
this gives you a little more insight to the high flow filters... Dale
SR-033
