[rebel-builders] VGs
Bill Maxwell
Post by Bill Maxwell » Sun Feb 19, 2012 10:57 am
Very interesting Walter. Which particular VGs did you use?
Bill, 753R
To: "Rebel-Builders" <rebel-builders@dcsol.com>
Sent: Tuesday, July 04, 2006 12:39 PM
Subject: [rebel-builders] VGs
I bought these for another airplane, but thought I would try them first
temporarily on my amphib Rebel to see what difference they made. After
attaching them with double sided carpet tape at the prescribed location on
the wing, I took it up for some stall trials. My gross weight was exactly
at
1650 for the test. I tried it first at the neutral flaperon setting. I
hadn't done a stall for a while, but seemed to recall it stalling between
45
and 50 mph at that weight with neutral flaperons. Well, I kept pulling
back
and watching my airspeed go all the way down to below 40 (around about 38,
think, as it doesn't read too accurately below that) before it finally
felt
like a stall at a ridiculously high nose angle. So there was definitely a
dramatic drop in stall speed. Because it was so slow already, I didn't
even
try it with full flaps.
However, it was harder to tell what difference if any it made to my
take-offs. When you are flying floats, you can't rotate at a high angle of
attack because of the float tails. My take-offs were plenty fast, but
never
had a chance to put it to the test in a high elevation lake on a hot day
or
with a real heavy load. At near sea level my take-offs were always pretty
fast anyway unless I was really loaded down. I flew this way for a couple
weeks, and it seemed to perform pretty well, but I had no quantitative way
to measure my take-offs or climb rates (which also seemed better).
I did not notice any other handling differences or change in cruise speed.
They are also supposed to improve low speed handling, but with floats and
my
previous 50 mph stall speed, I usually would never fly below about 70
anyway.
So for this long weekend, I removed the VGs to see if I would notice a
difference again. Of course the first thing I tried was the stall speed
once
I had the right fuel quantity to make it 1650 gross again. This time it
buffeted at around 50 with a clear fast dropping stall by 48 mph. That
means
the VGs probably improved stall by about 10 to 12 mph which is a lot more
than I expected. And that was at neutral flaps.
I did a few take-offs on land and water, and sure enough it seemed to be a
little longer to take-off without the VGs. It was especially noticeable on
the water, where I needed to be a little more patient so I didn't ruin my
sweet spot trying to lift it off early. Also, my climb rate also seemed
lower by about 2 or 300 fpm.
The only problem with this testing, is that it is a little too qualitative
(other than the stalls), so am not prepared to say with certainty, that
VGs did indeed improve take-offs and climbs. The real test would be at
higher altitudes with a good load and I just haven't had a chance to try
that yet. Also, taking off beside another Rebel would help.
However, next week I will be flying with Bruce G, so am going to put them
on
again, and see if we can get a better sense of comparison with his plane.
Anyway, thought this would be of interest to the group, as I'm not sure if
there is anyone else out there flying a Rebel with the VGs.
If these things actually make a difference at high elevation lakes, then
maybe I won't need that 0360 clone after all.
Related to this, was talking to another Rebel float plane pilot, (won't
mention his name to protect the innocent) but he told me it took him half
an
hour this morning trying to get off a 3800 foot lake. He was pretty loaded
with camping gear, full fuel and his wife, so I was not surprised, even
though he had the 160 hp 0320 (mine is only 150 hp). He said his biggest
problem was getting on the step, and he finally did it after he got a
little
headwind breeze. He said he tried every trick in the book, with wakes,
rocking it, flaps, no flaps, but it just wouldn't go. Once on the step, he
eventually was able to raise one float, allowing it to gain more speed
until
he finally lifted off. He had to keep flaps in neutral initially, and then
full flap at speed to lift off.
So that would have been a good test for the VGs.
Post by Walter Klatt » Sun Feb 19, 2012 10:57 am
These are the ones I tried. Cheap, only $95 US.
http://landshorter.com/
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Bill
Maxwell
Sent: July 3, 2006 8:19 PM
Subject: Re: [rebel-builders] VGs
Bill, 753R
at
45
back
felt
even
never
or
my
anyway.
once
means
on
an
little
until
Bill Maxwell
Thanks Walter
Sent: Tuesday, July 04, 2006 1:51 PM
Subject: RE: [rebel-builders] VGs
Maxwell
Bill, 753R
on
at
45
back
38,
felt
even
never
or
way
speed.
my
anyway.
once
means
on
qualitative
on
if
an
loaded
little
he
until
then
Post by Ken » Sun Feb 19, 2012 10:57 am
Thanks for the write up Walter. I love the idea of using carpet tape to
play with these things as they sure seem to have benefits.
I don't think VG's would help get on the step unless maybe they were on
the top of the stabilizer. Even then though I wouldn't expect much since
the prop blast is already providing good flow. On occasion we'd have
everybody up against the cockpit to get on the step and then have them
sit down for the takeoff on the larger floatplanes ;)
It would be interesting to note the GPS speed difference between 50 ias
and 40 ias. There might not really be 12 mph between 50 and 38
indicated. I think that most ias falls off more quickly than real
airspeed at the low end. I'd guess that VG's would show the most
improvement with full flap if you decide to play with that.
snip
WALTER KLATT
Post by WALTER KLATT » Sun Feb 19, 2012 10:57 am
Ken, I was thinking too, that the real difference is not 12 mph, because at extreme angles of attack, which is what the VGs give you, the airspeed indicator is also far from direct to the airflow. But that is what my IAS was showing. I might mention also, that on my airplane, my pitot is pointed more down than most (a refueling contact incident), so that it probably reads higher than most Rebels during the stall. I am not sure if checking IAS against my GPS is useful at those low speeds if comparing with VGs against no VGs, due to the differences in angles of attack. An absolute comparison of groundspeed, however, should do it, but not sure how good I can fly 3 headings at stall speeds to get a proper average.
As for getting on the step, that is indeed where I think the VGs might help. That is because they provide more lift at a higher angle of attack which is what you have when trying to get on the step. So if the wings can lift more instead of just the floats pushing/plowing water, then they should help. The elevator seems to have good authority on the water even at low speeds, so not sure if that would help, but might be worth a try as well.
With my airplane, I have never had trouble getting on the step, but I have had some pretty long runs to lift off at higher elevations. It
Hi Walter
I guess I always assumed that there is not much wing lift prior to
getting on the step but you reminded me of a time I got airborne before
getting on the step. It was exciting (OK scary!) but the wind was pretty
strong that day and I was in a fairly fast moving river as well.
I don't recall that leaving the flaps up helped getting an Otter onto
the step. That might indicate that we were indeed getting some lift and
the flaps helped increase it and move the center of lift aft. We also
always thought that the flaps help deflect the propblast downwards and
that it then tended to bounce back off the water and help lift the tail.
I have no idea what works best on a Rebel of course.
WALTER KLATT wrote:
[quote]Ken, I was thinking too, that the real difference is not 12 mph, because at extreme angles of attack, which is what the VGs give you, the airspeed indicator is also far from direct to the airflow. But that is what my IAS was showing. I might mention also, that on my airplane, my pitot is pointed more down than most (a refueling contact incident), so that it probably reads higher than most Rebels during the stall. I am not sure if checking IAS against my GPS is useful at those low speeds if comparing with VGs against no VGs, due to the differences in angles of attack. An absolute comparison of groundspeed, however, should do it, but not sure how good I can fly 3 headings at stall speeds to get a proper average.
WALTER KLATT
I remember playing around a few years ago, starting with no flap and then adding later at speed, and recall that I didn't notice a measureable difference. So, to keep it simple, I always start now with full flaperons down. If I ever get into a real marginal situation at a higher elevation lake, I will be in a better position to determine what works best, but so far have always got off with my method.
I often get practice at my cabin on Harrison Lake taking off in strong winds. And I learned early on not to get airbourne prematurely as you will just pound back down harder into the waves if that happens. What works best with me, is get it up on the step quickly timing a wave, but let it just skip the tops of a few before pulling up. That way, I take the least pounding and am airboure very quickly, usually in about 10 seconds or less. There is no question that a strong breeze gets you up on the step more quickly. I think this is where the VGs can help as well, with providing more aileron authority at low speeds. At my lake, I sometimes start my take-off run in a cross wind, and have experienced that 2 second feeling where the plane is barely flying, and the wind is trying to pick up that upwind wing (and push your downwind float back into the water which would be very bad news) despite appling full aileron into the wind.
Date: Tuesday, July 4, 2006 9:38 am
Hi Walter
before
pretty
onto
lift and
also
tail.
average.>
elevations. It
Bruce Georgen
Post by Bruce Georgen » Sun Feb 19, 2012 10:57 am
HI Walter,
That will be a good test as we have the same engine and prop with the same pitch now, as you may remember I had mine re-twisted last year. I'm still planning on flying to Arlington Friday morning. I think you said you would be there Saturday? See you then.
Bruce G
Sent: Jul 3, 2006 10:39 PM
To: Rebel-Builders <rebel-builders@dcsol.com>
the wing, I took it up for some stall trials. My gross weight was exactly at
hadn't done a stall for a while, but seemed to recall it stalling between 45
and 50 mph at that weight with neutral flaperons. Well, I kept pulling back
and watching my airspeed go all the way down to below 40 (around about 38, I
think, as it doesn't read too accurately below that) before it finally felt
dramatic drop in stall speed. Because it was so slow already, I didn't even
attack because of the float tails. My take-offs were plenty fast, but never
had a chance to put it to the test in a high elevation lake on a hot day or
fast anyway unless I was really loaded down. I flew this way for a couple of
They are also supposed to improve low speed handling, but with floats and my
anyway.
difference again. Of course the first thing I tried was the stall speed once
buffeted at around 50 with a clear fast dropping stall by 48 mph. That means
(other than the stalls), so am not prepared to say with certainty, that the
However, next week I will be flying with Bruce G, so am going to put them on
mention his name to protect the innocent) but he told me it took him half an
problem was getting on the step, and he finally did it after he got a little
eventually was able to raise one float, allowing it to gain more speed until
PeoplePC Online
A better way to Internet
http://www.peoplepc.com
Post by Walter Klatt » Sun Feb 19, 2012 10:59 am
Yup, will be there Sat AM, and am planning to camp overnight and we can head
back on Sunday. Wife is hosting a shower on Sat night, so wants me out of
the house then.
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Bruce
Georgen
Sent: July 4, 2006 9:06 PM
HI Walter,
Bruce G
at
45
my
anyway.
once
means
on
an
little
until
PeoplePC Online
Garry Wright
Post by Garry Wright » Sun Feb 19, 2012 5:58 pm
Thanks for the note Ike. Very useful info esp re the elevator.
Garry
ike isaacson wrote:
Hi everyone,
I thought I'd add my experiences on vgs. I've had them on since the
90s and I love them. I was the first Rebel to use Micro Aerodynamics
and did some experimenting. The normal rule of thumb is to install
the leading edge of the vg at 10% of the cord, which for us is 6
inches. This is a compromise for a stall speed reduction and minimal
impact on cruise. I chose to put them at 2.5 inches back as I wanted
to really lower my stall and was willing to take a hit on cruise
speed. Moving forward of 10% into the high pressure point of the
leading edge creates a lot of drag. However, my Rebel doesn't stall,
it starts a controlled mush at about 37-38 mph at 3500 feet. This
location keeps the airflow attached to the wing, but a side effect is
a very high angle of attack for landing. I would touch down tail
wheel first, then as the AOA lowered, it would drop on the mains. So
I installed 29 inch Alaska Bushwheels and that problem was solved. I
went to split flaps before Murphy offered a retrofit kit, and tried 6
inches back from the wing root to the end of the flaps and 2.5 inches
from mid wing to the tips, but the stall wasn't as low as the full
wing at 2.5 inches. So, with all the drag of vgs and tires, my cruise
is about 85mph. However, at both 6 and 2.5 inches, the aileron
response is much crisper, even at 40mph.
When I have time, I want to play with either a slotted or Fowler type
flap for slower speed and a low nose angle. Daryl Murphy told me the
flap brackets we have are designed for a max of 25 degrees, so a new
mounting bracket/hinge setup will be required. Big flaps are nice
cause they move the center of lift back giving you a better over the
nose view for landing and a slower speed. The only draw back may be a
lack of elevator authority cause of wing flow deflection.
One last item concerning vgs is the horizontal stab and elevator. In
the past, I've had a few instances of being light for landing
(forward cg) and come in at an idle and rounded out for the flare,
but the tail wouldn't respond. What was happening was the elevator
was stalling as I pulled back on the stick (high elevator deflection
and no prop blast for airflow). I put Micro Aerodynamics vgs on the
bottom only of the stab right in front of the elevator. A huge
difference in control with no reduction in speed and absolutely no
elevator stall ever. Even if you don't want wing vgs, I highly
recommend the elevator install.
One last thing, I tried the Turbine Cubs of Wyoming slats that Wayne
Mackay designed last summer. All I can say is don't do it. They work
great for a flat bottomed airfoil like a Cub or Maule, but are an
absolute disaster with the 4415 airfoil that the Rebel uses.
Thankfully, they took the slats back for a full refund. If anyone
wants to talk about whatever, I'm at 509-995-6372, Spokane, WA
(Pacific time). Thanks
Post by Walter Klatt » Sun Feb 19, 2012 5:58 pm
Hi, Ike. Thanks for the great information, very interesting. On your stabs,
what spacing did you used for the VGs?
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of ike
isaacson
Sent: Wednesday, January 20, 2010 9:42 PM
To: rebel-builders-d@dcsol.com
Hi everyone,
