Ailreron Leading Edge Ribs
T L McClary
Post by T L McClary » Fri Feb 17, 2012 5:40 pm
I have to ask so I don't start my project by building the first part
wrong.
When I look at the right aileron drawing it appears that for a right hand
aileron you use 1 left leading edge rib and 6 right leading edge ribs so
that you have a closed cavity. The rib install instructions just say
make sure the rib flanges are facing the correct direction so I could use
7 right hand leading edge ribs so that the flanges all face in the same
direction. The drawing parts list gives the quantities for all 4
ailerons, instead of the quantity necessary to build the one part that is
illustrated.
My left hand leading edge ribs are on back order so if I had them I could
fit the parts and my question would probably go away. Getting impatient
on waiting for the back order, I want to start building so I am throwing
the question out.
Terry
Rebel #666
________________________________________________________________
YOU'RE PAYING TOO MUCH FOR THE INTERNET!
Juno now offers FREE Internet Access!
Try it today - there's no risk! For your FREE software, visit:
http://dl.www.juno.com/get/tagj.
