Seems like a few of us are about the same point in the game. :)
So here's where I'm a little stumped... MAM says when drilling thru skin holes
to bulkheads, to not drill into bulkhead A. Fine enf, this implies that comes
later when the next section of fuse is joined. But MAM does say to drill and
rivet on the corner wraps, which *do* pick up bulkhead A, as well as the
second bulkhead made for the float attach points.
Should I rivet the corner corner wraps to bulkhead A and the float bulkhead
at this point? If so, I spose fine to rivet skins to the float bulkhead too.
TIA,
-Ben
