[rebel-builders] Riveting fus skins
Post by Ken » Sun Feb 19, 2012 10:56 am
I followed the manual however I did have to remove the short top skin
section immediately ahead of the fin to put in the controls. You can't
crawl inside like that though with the aft end only supported by the
tailspring. I supported the fuselage under some of the bulkheads to work
inside.
apoulsen wrote:
Hello all,
I've read through the archives searching for information on riveting the skins and corner wraps on the aft fus. There seems to be some disagreement as to whether one should rivet them as directed by mam or at some later time to allow for access later on. I have to build the fus in pieces and the longest section I have room for is 12' so I would like the parts a rigid as possible for moving around but I don't want to end up with some horrible access problem later.
Any thoughts?
Allen Poulsen
786R
Post by Drew Dalgleish » Sun Feb 19, 2012 10:56 am
Aw come on Ken you're skinny heck I fit way back there and I still crawl
back twice a year to visit my elt.
inside.
apoulsen wrote:
Hello all,
Any thoughts?
Allen Poulsen
786R
Post by Mike Kimball » Sun Feb 19, 2012 10:56 am
I built a Super Rebel but it sounds like the same type of thing is going on
with the Rebel. I not only left the last piece on top just in the front of
the fin off, but I also left the last two upper corner wraps off until I was
all done with controls. This made it a lot easier for me. If you do this,
absolutely do not try and crawl back there. My buddy did that and damaged
the tailcone. He had to replace both sides and some other stuff.
044SR
apoulsen
Sent: Friday, June 16, 2006 4:21 PM
Subject: [rebel-builders] Riveting fus skins
Hello all,
Any thoughts?
Allen Poulsen
786R
N.Smith
Post by N.Smith » Sun Feb 19, 2012 10:56 am
Can I just say DO NOT crawl inside EVER without it supported in the middle
if that panel is removed.
Just finishing the repair now !!
Nig 745E
Sent: 17 June 2006 05:10
Subject: Re: [rebel-builders] Riveting fus skins
inside.
apoulsen wrote:
Hello all,
Any thoughts?
Allen Poulsen
786R
apoulsen
Post by apoulsen » Sun Feb 19, 2012 10:56 am
You can say! i still can see the pictures.
Allen
Sent: Saturday, June 17, 2006 4:03 AM
Subject: RE: [rebel-builders] Riveting fus skins
Nig 745E
inside.
apoulsen wrote:
Hello all,
Any thoughts?
Allen Poulsen
786R
Hi Drew
Four pulleys, ELT, antenna, four control cable holes and a retractable
ground handle went in through that open panel. Maybe the battery for
some fellows as well.
And it provided ventilation when I did the floor as I had a fan blowing
air down the fuselage and out that hole ;) (With a sawhorse and a
sheet of wood under the bulkheads for support!)
Thinking about Allen's question further - it might be a good idea to
install the floor channels back there before completely riveting the
tailcone as well. Some guys have even put in the floor.
That retractable handle is well "handy" but not as beneficial as I
expected. The tail ready to go with fuel is heavy enough (as is the
airplane) now that a "towbar" attached to the tailwheel would be better
for pulling it around on the ground.
I'm just waiting for the C of A.now. For the first time in 9 years I
have nothing on my airplane to do list. Mentioned that to the wife and
she suggested that I should install a carpet while I wait since I'm even
almost caught up on my neglected household chores. Guess I could make a
towbar too. Well there goes my empty to do list...
inside.
apoulsen
Surely you can thing of "something" to do on the airplane rather than work
on the house!!!
Thanks all for the input
Allen
Sent: Saturday, June 17, 2006 8:31 AM
Hi Drew
inside.
Jesse Jenks
Post by Jesse Jenks » Sun Feb 19, 2012 10:56 am
This is a timely discussion for me. I was just about to rivet that area. I
thought about leaving that section of skin off, but how do you pull the two
rivets that sit under the fin leading edge? I guess I could pull them from
inside, except that I already dimpled the holes (unnecessarily, I just
dimpled all the holes around the top of the oval bulkhead to avoid
confusion) Can you put a regular rivet in the back of a dimpled hole?
Jesse
Date: Sat, 17 Jun 2006 08:31:08 -0400
Hi Drew
inside.
Post by Bob Patterson » Sun Feb 19, 2012 10:56 am
Hi Allen !
You might want to rivet all, except for the top corner wraps
and the side panel on one side - just cleco those in place. This will
give easy access later ...
One builder here did exactly that - and kept the tail cone
separate from the cabin until he moved all the pieces to a hangar
for final assembly. It worked out great ! Took almost 3 months
to get it all together and ready to fly, though - but he only had
Saturdays and a couple of evenings a week to work on it ...
Keep rivetting - it IS worth it !!! :-)
On Saturday 17 June 2006 12:20 am, apoulsen wrote:
Hello all,
problem later.
Any thoughts?
Allen Poulsen
786R
Yes I did those (two I think) from the inside. Personally for two holes
I wouldn't hesitate to leave them dimpled and still rivet them from the
opposite side.
Jesse
apoulsen
Thanks Bob, that's the conclusion I reached too.
I'm going to put in the floor with the side off instead of climbing around
inside. If I run into any problems doing it that way I'll post them.
Allen
Sent: Saturday, June 17, 2006 12:07 PM
Hi Allen !
Hello all,
as
longest
possible
problem later.
Any thoughts?
Allen Poulsen
786R
Jesse Jenks
Thanks Ken,
That's what I will do. I just riveted the bottom fus 29 and fus 30 on. Glad
Alan brought it up. This will make it much easier to work back there. Just
have to remember not to crawl in.
Jesse
Date: Sat, 17 Jun 2006 12:50:20 -0400
opposite side.
two
from
Jesse
