[rebel-builders] moose seaplane door
Post by Mike Kimball » Sun Feb 19, 2012 10:53 am
I would assume that the bubble would not allow you to open the door as far
as a non-bubble window would since the door will be hinged only a couple of
inches below the bottom of the wing. But it may still be acceptable for
getting in and out. You will want to restrict the door opening so you
aren't constantly banging the window into the wing.
044SR
bscheube@dcsol.com
Sent: Tuesday, June 06, 2006 9:46 AM
Subject: [rebel-builders] moose seaplane door
Hi all,
I have done a seaplane door mod on my Moose Fus. My question is about the
bubble windows for the door that Murphy offers....Is there any clearance
issues under the wing when the window and/or door is in the open position?
I have an order ready to go at MAM and was thinking about adding them to
my order.
thanks for the response.
Bob Scheuber
Bill Smith
Post by Bill Smith » Sun Feb 19, 2012 10:53 am
Isn't the Murphy "bubble" only about 1/2 to 3/4 inch. Looking at
Scott's pictures it doesn't look like the bubble makes much
difference.
044SR
bscheube@dcsol.com
Hi all,
my order.
Bob Scheuber
Really? If that's the case, why bother? I'm curious. With the curve, is
it still optically correct? I know some motorcycle windshields aren't.
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Bill
Smith
Sent: Wednesday, June 07, 2006 6:01 PM
Subject: Re: [rebel-builders] moose seaplane door
difference.
044SR
bscheube@dcsol.com
Hi all,
my order.
Bob Scheuber
mike.davis
Post by mike.davis » Sun Feb 19, 2012 10:53 am
When I first saw the bubble window, what... 4 years ago now, Colleen
explained to me that it made the window much more rigid, the flat windows
apparently flex a bit. It's not a bubble like the windows designed for
photographing. I seem to remember that it added 3" width at the shoulder,
but I'm not positive about that.
On 6/8/2006 9:52 AM, rebel-builders@dcsol.com wrote to MIKE DAVIS:
-> Really? If that's the case, why bother? I'm curious. With the curve, is
-> it still optically correct? I know some motorcycle windshields aren't.
-> Mike
-> -----Original Message-----
Bill
-> Smith
-> Sent: Wednesday, June 07, 2006 6:01 PM
-> Subject: Re: [rebel-builders] moose seaplane door
-> Isn't the Murphy "bubble" only about 1/2 to 3/4 inch. Looking at
-> Scott's pictures it doesn't look like the bubble makes much
-> difference.
-> On 6/6/06, Mike Kimball <mkimball@gci.net> wrote:
-> > I would assume that the bubble would not allow you to open the door as
far
-> > as a non-bubble window would since the door will be hinged only a
couple
-> of
-> > inches below the bottom of the wing. But it may still be acceptable for
-> > getting in and out. You will want to restrict the door opening so you
-> > aren't constantly banging the window into the wing.
-> > Mike
-> > 044SR
-> > -----Original Message-----
-> > From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of
-> > bscheube@dcsol.com
-> > Sent: Tuesday, June 06, 2006 9:46 AM
-> > To: rebel-builders@dcsol.com
-> > Subject: [rebel-builders] moose seaplane door
-> > Hi all,
-> > I have done a seaplane door mod on my Moose Fus. My question is
about the
-> > bubble windows for the door that Murphy offers....Is there any clearance
-> > issues under the wing when the window and/or door is in the open
position?
-> > I have an order ready to go at MAM and was thinking about adding them
-> > my order.
-> > thanks for the response.
-> > Bob Scheuber
-> > List archives located at: https://www.dcsol.com/login
-> List archives located at: https://www.dcsol.com/login
