I can't help you with the baffles, but I do have the same engine (not
mounted) from George Coy. Would be very interested in what you end up with,
it could help those of us with the same or similar engine. Also, are you
using the Murphy cowling, or are you making your own? I heard the Murphy
cowling won't fit the G1D5 without modifications.
Tom Packard
SR 043
Sent: Wednesday, May 31, 2006 12:28 AM
Subject: [rebel-builders] SR IO-540 baffles
have paper templates for the baffles that came with the engine but it turnsI finally got the engine mounted and am ready to start on the baffles. I
out the pattern is for an O-540. The cut outs for the cylinder heads are
different; I suppose this is the difference between parrallel valve and
angle valve engines. Mine is an angle valve (IO-540-G1D5). Where can I find
templates for this engine? Better yet, does anyone have notes and pictures
for a similar install? I could modify the O-540 templates to fit but I'm
worried that there might be other dimensional differences that will make
this more work than it seems.
Tim
SR060
--- http://USFamily.Net/dialup.html - $8.25/mo! -- http://www.usfamily.net/dsl.html - $19.99/mo! ---
