[rebel-builders] Aileron bushing length?
charles eubanks
Post by charles eubanks » Sun Feb 19, 2012 10:52 am
I don't know if the AIL-26 bushings for the standard Rebel are the same but
mine are made out of stainless steel and measure .375 Dia. x .258 ID. x .558
Lg. Hope this helps.
Charlie 802R
To: "Rebel Builder's List" <rebel-builders@dcsol.com>
Sent: Monday, May 29, 2006 12:28 AM
Subject: [rebel-builders] Aileron bushing length?
Does anyone have an AIL-26 aileron bushing they can measure for me? I
can't
find any of the ones I'm supposed to have but I have a bit of 4130 steel
tubing that I can make my own. I measured the brass fitting the bushing
goes into and it is 0.48 inches. I know the steel bushing should be a bit
longer but I'm not sure how much longer works the best. Too long and the
flaps and ailerons can move too much side to side. Too short and they may
not move at all.
044SR
Dale Fultz
Post by Dale Fultz » Sun Feb 19, 2012 10:52 am
Hi Mike,,, The bushing on my Moose are the .5625 and are made of stainless
steel.. Dale SR-033
Robert and Olga Johnson
Post by Robert and Olga Johnson » Sun Feb 19, 2012 10:52 am
Mike: The AIL 26's I have for Moose 226 are .370 O.D. x .251 I.D. x .557 lg.
They are definitely not stainless steel as there is slight rusting on the
O.D.in (was) a sealed package. - Bob J
Sent: Monday, May 29, 2006 1:28 AM
can't
not move at all.
044SR
apoulsen
Post by apoulsen » Sun Feb 19, 2012 10:52 am
I don't have a micrometer but my eyeball / ruler concurs with Charlie's
measurements.
Allen Poulsen
786R
can't
not move at all.
044SR
Post by Mike Kimball » Sun Feb 19, 2012 10:52 am
Thanks everyone! I can start cutting now.
apoulsen
Sent: Monday, May 29, 2006 8:49 AM
Subject: Re: [rebel-builders] Aileron bushing length?
measurements.
Allen Poulsen
786R
can't
not move at all.
044SR
mike.davis
Post by mike.davis » Sun Feb 19, 2012 10:52 am
You're welcome to come by and take a look at mine if you want to Mike.
On 5/29/2006 5:27 PM, rebel-builders@dcsol.com wrote to MIKE DAVIS:
-> Thanks everyone! I can start cutting now.
-> Mike
-> -----Original Message-----
-> apoulsen
-> Sent: Monday, May 29, 2006 8:49 AM
-> Subject: Re: [rebel-builders] Aileron bushing length?
-> I don't have a micrometer but my eyeball / ruler concurs with Charlie's
-> measurements.
-> Allen Poulsen
-> 786R
