Rebel forward tailspring bolt bracket
Jesse Jenks
Post by Jesse Jenks » Sun Feb 19, 2012 10:52 am
I won't refer to it by the part number because what is written on the part
is different than what the manual says, but it's the part that the forward
AN-6 bolt goes through. The manual says to just drill it to 3/32 and install
it and close up the tail to be drilled to fit later. When I flipped forward
to the tailspring attachment, it says to drill it out from the inside of the
fuselage?? That would be difficult at best with the FUS-31 riveted in. Is
there a good reason not to drill it to final size now, while I can put it on
the drill press?
Jesse
