.049 would have been adequate but thicker was easier to weld for an amateur.
R. Finch was probably in the ballpark in his book for a V-8 and from
memory I believe he was recommending 1" x .065.
Generally the larger diameter tubes are needed for long tubes in
compression whereas cross bracing and tension tubes may not need to be
so large.
rickhm@comcast.net wrote:
I am taking a brief survey of those who have built their own engine mount. I'm hoping Mike K. will respond. What size tubing and wall thickness is the majority of engine mounts constructed from? I am building a SR2500 with a V8.
Rick Muller
SR70
