[rebel-builders] RE: engines / fuel
Brian Breathnach
Post by Brian Breathnach » Sun Feb 19, 2012 10:47 am
Very interesting article on aircraft fuel, and alternatives, in the May
issue of AOPAPILOT
Brian
Sent: Friday, May 12, 2006 2:54 PM
Subject: [rebel-builders] RE: engines / fuel
Yep, the STC's are for the airframe with a particular engine. Fuel flow
tests
on some airframes were inadequate (They wouldn't pass on avgas either, but
common sense never prevails!) I once new a guy who new a guy who new
about somebody with an IO-470 Bonanza that ran auto fuel in cruise, using
100LL only for take-off and landing. Cooler CHT, clean plugs, no problems
whatsoever with bladders, vapor lock etc.
5/11/2006 7:28 PM, rebaker@sc.rr.com wrote to rebel-builders:
-> There are other allied concerns with mogas than just the lead.
Remember
that mogas is formulated both by region and season and its distribution is
not
tracked as is 100LL. For one, the mogas vapor pressure is higher and
increasingly so in winter formulations. The STCs all apply to certified
aircraft
with consistent construction (at least we hope so) and before an STC is
issued an extensive flight test program is done to ensure the mogas
operates
in that specific aircraft safely. An example wmight be that fuel lines do
not
boil and vapor lock due to exhaust proximity.
-> On another subject Ben Visser (ex Shell ) noted that mogas and 100LL
can
be mixed in any proportion and that the octane rating change is not
linear.
In other words that initial addition of 100LL gives more octane number
boost
than later additions. An example of diminishing returns. There is no
formula
to determine what percentage of added 100LL gives what percentage
increase. It's related to the many combinations of petroleum molecules
additives that can be used to make fuel. As I have stated before, Visser
said
some time back that a conventional Lyc or Continental run on 100LL for the
first 300 hours after rebuild would make TBO on auto fuel if operated
correctly on adequate octane for that engine.
-> Ralph Baker
