[rebel-builders] Moose wing struts
Jeff McMurrer
Post by Jeff McMurrer » Sun Feb 19, 2012 10:47 am
What are you getting for degree setting for dihedral?
Jeff
Date: Sunday, May 7, 2006 2:59 pm
Subject: [rebel-builders] Moose wing struts
Has anyone else had problems with the fast build struts not
fitting being to long or to short??? Mine seem to bee to long and
can't get the right dihedral called for in the manual.. Dale SR-033
Dale Fultz
Post by Dale Fultz » Sun Feb 19, 2012 10:47 am
filed the holes by hand rather then drilling at first then drilled and
reamed and got them to 1.3 degrees and called it good..Dale SR-033
