Moose build
Robert and Olga Johnson
Moose build
Post by Robert and Olga Johnson » Sun Feb 19, 2012 10:44 am
This is a question for you Moose builders. I am working on a quick build Moose fuselage, however the manual supplied is for the SR2500. Is there a manual for quick builds or is it a mater of going thru the SR2500 manual and adding what has not already been done?? I would also like to question the spring landing gear which I feel is extremely heavy weight wise. I can not even lift the two legs together. Also the manual says to use size 10 bolts for the 3500 which I have , but the pre-installed brackets are drilled for size 8. I am sure some of you must have crossed this bridge already. Help appreciated. Thanks. Bob J (formerly Rebel 652, 725, and now Moose 226
