Rebel Wheel alignment/Tow out
steve whitenect
Post by steve whitenect » Sun Feb 19, 2012 10:39 am
Hi all
Can anyone remember off hand the desired tow out distance at the front and
rear with spring gear? Was it 1/4 inch? Thought I kept the thread on it's
last discussion but can't find it by searching the mail.
Thanks to those who respond
Steve W 637R
Subject: Re: [rebel-builders] USA LSA aircraft
Date: Thu, 13 Apr 2006 13:36:50 -0400
FWIW,
I'm building my Rebel for LSA but I wondered about eventual resale to
someone who wants the higher gross so I asked the EAA and the FAA at Sun N
Fun and of course got two different answers. The guys at EAA insist that
you
can't up the weight later but the FAA said its no problem. I specifically
asked about upping the weight with (re-engine) and without physical changes
and the FAA was emphatic that its just paperwork either way. Will the next
Fed you ask give a different answer? Who knows.
Allen Poulsen
786R
P.S. Enjoyed meeting and talking with you Ralph. Bob, sorry I didn't get to
thank you personally for the beer. and I promise to drink more next year.
Sent: Thursday, April 13, 2006 12:33 PM
Subject: [rebel-builders] USA LSA aircraft
Bob,
The LSA specs do not require any special resistration. All that is
required is that the aircraft meet the LSA specs. It can be amateur
built
or certified. If it is an SLSA (factory completed) there has to be an
acceptance by the FAA that it complies with the ASTM standards. Not
sure
about the ELSA as that is an unattractive option at present to all
parties.
As far as I know, any Canadian amateur built that is properly registered
and can legally be imported to the USA and registered here can be flown
by
a Sport Pilot as long as it meets the LSA specs.
