[rebel-builders] Rebel/Elite Float Hydraulic Reservoir Size
Post by Wayne G. O'Shea » Sun Feb 19, 2012 10:38 am
All you absolutely need Terry is the differential volume between gear up and
gear down. Probably not much more than a pint.
BUT.... :O) .... consider you blow a line while pumping gear up and you give
it two or four strokes before you realize this. So by now 1/2 a quart is
gone. IF you select gear down at this point you would have enough fluid left
in the MAM reservoir to get the gear back down and locked.... to land back
at the home strip and fix your plumbing. With your mini reservoir that you
are contemplating you'll be looking for some grass to slide on...... since
the gear will be mid range and nothing you can do with it!
As always...just food for thought!
To: "Murphy Group" <rebel-builders@dcsol.com>
Sent: Monday, April 03, 2006 3:33 PM
Subject: [rebel-builders] Rebel/Elite Float Hydraulic Reservoir Size
Hello Amphib Float Builders/Flyers:
I am thinking of fabricating an aluminum float pump hydraulic reservoir
that will bolt to the aft end of an extended length float pump base.
Looking from the top, it will have a racetrack shape similar to the
shape of a pint can of solvent. The MAM plastic windshield washer
reservoir looked a bit large to me.
My question is: what is the optimum (smallest) capacity for this amphib
float landing gear reservoir unit. A pint? A quart? Or?
If anyone that has done this, do you have parts numbers for the quick
disconnect fittings, threaded inserts etc.
Suggestions? Comments?
Thanks in advance.
Terry Dazey
Rebel 662
Lake Tapps, WA U.S.A.
WALTER KLATT
Post by WALTER KLATT » Sun Feb 19, 2012 10:38 am
I wouldn't want it too small though, in case you get caught way out in the boonies somewhere with a leak. That little extra can get you home again. Bruce G. can testify to this as well.
Date: Monday, April 3, 2006 2:30 pm
Subject: Re: [rebel-builders] Rebel/Elite Float Hydraulic Reservoir Size
gear up and
and you give
quart is
fluid left
land back
that you
on...... since
reservoir> that will bolt to the aft end of an extended length
float pump base.
amphib> float landing gear reservoir unit. A pint? A quart? Or?
quick> disconnect fittings, threaded inserts etc.
Thanks in advance.
Terry Dazey
Rebel 662
Bruce Georgen
Post by Bruce Georgen » Sun Feb 19, 2012 10:38 am
Yes, been there...done that. :-)
Bruce G
Sent: Apr 3, 2006 6:36 PM
gear up and
and you give
quart is
fluid left
land back
that you
on...... since
float pump base.
Thanks in advance.
Terry Dazey
Rebel 662
PeoplePC Online
A better way to Internet
http://www.peoplepc.com
Bruce Georgen
But the trout your wife cooked up for us that evening made up for that part of the day. All is well that ends well.
Bruce G
gear up and
and you give
quart is
fluid left
land back
that you
on...... since
float pump base.
Thanks in advance.
Terry Dazey
Rebel 662
PeoplePC Online
Terry Dazey
Post by Terry Dazey » Sun Feb 19, 2012 10:39 am
Okay Wayne, you convinced me. I will make it a quart, AN fittings and aluminum
lines!
Terry Dazey
Rebel 662
Lake Tapps, Washington USA
