Just a post to see if there is a sufficient number of people that would be
interested in buying a photo library of how to build the 1800 amphibs. I'm
currently well beyond 300 in process pictures, with paper notes/dimensions
or writing directly on the parts in the pictures where required to correct
manual errors or building tips to speed/improve construction (such as the
picture I linked on how to align/square the main gear mechanism a while
back). I figure based on where I am and where I have to get to there will
probably be 500 to 600 pictures by the time this set makes it onto the
airplane. Will also add installation pictures of various installations of
1800's as well.
Just seeing if there is enough interest for such a CD and if so once we have
an approximate number we can determine if we'll bother and set a price. Most
likely be done in a slide show presentation so it can be copy protected....
as we're not going to go to the trouble only to have it boot legged.
1800 Amphib Float building pictorial manual
I'll take one RIGHT NOW! ... I'll be starting the amphibs this month!
On 3/28/2006 6:40 PM, oifa@irishfield.on.ca wrote to rebel-builders:
-> Just a post to see if there is a sufficient number of people that would be
-> interested in buying a photo library of how to build the 1800 amphibs. I'm
-> currently well beyond 300 in process pictures, with paper notes/dimensions
-> or writing directly on the parts in the pictures where required to correct
-> manual errors or building tips to speed/improve construction (such as the
-> picture I linked on how to align/square the main gear mechanism a while
-> back). I figure based on where I am and where I have to get to there will
-> probably be 500 to 600 pictures by the time this set makes it onto the
-> airplane. Will also add installation pictures of various installations of
-> 1800's as well.
-> Just seeing if there is enough interest for such a CD and if so once we
have
-> an approximate number we can determine if we'll bother and set a price.
Most
-> likely be done in a slide show presentation so it can be copy protected....
-> as we're not going to go to the trouble only to have it boot legged.
-> Cheers,
-> Wayne
-> 1800's as well.
have
Most
-> Cheers,
-> Wayne
