[rebel-builders] Rebel Transponder & Com radios
Post by Wayne G. O'Shea » Sun Feb 19, 2012 10:35 am
The newer models of the Val have a battery in them to hold the frequency. I
believe you can also upgrade the older ones to do the same.
Other problem I find with the VAL is sooner or later that little flip-flop
toggle switch causes you fits...doesn't it Garry!
Sent: Tuesday, March 28, 2006 9:01 PM
Subject: Re: [rebel-builders] Rebel Transponder
FWIW - I have dual VALCOM VHF in my SR and have had excellent results. My
only complaint with them is that when power is removed they do not hold
last freq. but revert to 121.9 and 121.7 on the flip flops. No problem to
again select the desired freq. when re-powering for next flight. Size is
about the same as ICOM and price is much less.
Charlie Starr
Sent: Tuesday, March 28, 2006 11:15 AM
Hi Jim !
I've had good luck with the VAL-COM units. They're about the same
size as the Icoms, but have a better display - lighted tubes that dim
automatically at night. Same flip-flop channel setup, but with flip
switch rather than push switch. Big attraction was price - $650 or
less .... and fabricated wiring harness for an extra $75.
On Tuesday 28 March 2006 11:10 am, pequeajim@dcsol.com wrote:
That was one that I was looking at, thanks. It is reasonably priced
readily available.
On 3/28/2006 4:22 AM, jean.poirier@oxyportneuf.com wrote to
rebel-builders:
-> Hello Jim
-> As for the com, 3 years ago I have bought a Icom IAC200 flip/flop
digital -> for a PA22 I had. One of my best purchase, price, size
transmission -> were top notch!
-> Jean
-> Rebel 747R
-> From: <pequeajim@dcsol.com>
-> Sent: Monday, March 27, 2006 10:16 PM
-> Subject: [rebel-builders] Rebel Transponder
-> > I'm looking for a small com/transponder setup and am wondering
what
-> > suggestions you guys have? I have a Terra, but they were aquired
by
Free
-> > Flight and do not support my models any more. I though I would
sell
them
-> > on
-> > ebay since they work and then get something that will be
supported
if it -> > breaks in the future.
-> > A very small digital would be great.
-> > Jim!
-> > List archives located at: https://www.dcsol.com/login
Garry Wright
Post by Garry Wright » Sun Feb 19, 2012 10:35 am
My Valcom 720 flipflop switch did fail. I don't know how old the unit is
but it probably isn't any older than FOKM. BobP would have to remember
when he put it in. They are special switches of course and not something
most of us would try to replace by ourselves so accordingly expensive.
Probably not supposed to anyway since it is radio gear. I did not know
about the battery bit. Will check that out. Thanks.
Garry Wright
068R
Charlie Starr
Hi Jim !
what
by
sell
supported
Post by Drew Dalgleish » Sun Feb 19, 2012 10:35 am
Garry Wright
068R
My valcom usually works well except about once a year it blows a fuse
and/or a diode for no apparent reason. Luckily the local FM radio repair
guy will fix it for about $20. I've also replaced the fuse myself but it's
an oddball and I think I spent more time tracking it down than it would
have taken to just get it fixed. The valcom is pretty long and only fits at
the bottom of the panel and it still sticks out about 1/2" if you have a
cut back firewall I don't think it will fit at all. For a really compact
radio that I've read good reviews on check out the micro-air radio and
transponder from austrailia.
