[rebel-builders] Moose Main Gear
pollock
Post by pollock » Sun Feb 19, 2012 10:34 am
Thanks for the heads up on 3/8 bolt size.What is the bolt size for the main
gear leg did they up the size??
Bill
Moose 244
Sent: Tuesday, March 21, 2006 7:58 PM
Subject: [rebel-builders] Moose Main Gear
Everyone that is working on or installed the 309's or the 309B's mounting
brackets into their Moose should check and MAKE SURE that the thru bolts
are 3/8 Dia.
The oridginel bolts were 5/16 Dia. MAM made a change to the size of the
bolt because of a seperation of a nut and bolt a few years back.
If you have the 5/16 Dia bolts in, remove them and drill and ream the
existing holes out to 3/8 Dia. Replace the 5/16 bolts with 3/8 bolts.
You will also have to enlarge the holes in the wrap so you can get the 3/8
bolts in and also to be able to get a socket onto the head of the bolt.
Steve H
Moose 213
