[rebel-builders] Screw skin pins??
Jean Poirier
Post by Jean Poirier » Sun Feb 19, 2012 10:34 am
Hello Ted,
I do have some fastener here that are may be what you call screw skin pin...
Look like a cleco (color and pin) but instead of spring loaded, you tight a
wing nut. Go on www.ustool.com part number TP109M-1/8. The Yard
www.yardstore.com show simular in type but used for $1.00 ea. Hope help
Jean
Rebel 747R
Sent: Tuesday, March 21, 2006 3:42 PM
Subject: [rebel-builders] Screw skin pins??
Dumb question I guess, but having not heard of these items before I did
a search on Aircraft Spruce using "screw skin pins" with no result. I
looked under "Sheet metal tools" with no result. I searched Google
using "screw skin pins" with no luck.
So what are these items and where does one get them?
N.Smith
Sent: Tuesday, March 21, 2006 1:06 PM
Subject: RE: [rebel-builders] Corner wrap joints, Rebel
Hi Jesse
It's worth getting some red ones (#40) and some yellow ones (#30) before
you start drilling. I messed up both top sides by using ordinary spring
cleco's and when I started riveting the extra pull meant the holes went
out of alignment as I approached the upper and lower edges. 2 new bits
from MAM later I used the screw skin pins and no problems second time
around. D'oh
Nig
745E
Jesse Jenks
Sent: 21 March 2006 16:53
Thanks Nigel,
I have seen those being used for this purpose in several pictures of
other Rebels. Unfortunately, I don't have any. Maybe it's time to order
some, or use the "baseball bat method" as Wayne describes. Come to think
of it, I don't have one of those either. Dang!
Date: Tue, 21 Mar 2006 07:03:25 -0000
Hi Jesse
I'd hold the radius tight down with screw down skin pins - not spring
ones when drilling. That way it will be held as flush as possible and
not change much when riveted.
Nigel
745E
Jesse Jenks
Sent: 21 March 2006 03:21
Subject: [rebel-builders] Corner wrap joints, Rebel
I am working on the upper corner wraps. Where the upper fus 10 (I am
using fus 70s) joins the fus 33 at bulkhead "B" it won't lay down
around the radius because of the taper. The manual shows something
involving a plywood cutout, but I wasn't sure what they are getting at.
Do I need to do some kind of forming of the radius edge of the fus 70
to make it fit properly, and if so what is the best way to do it? I am
tempted to just ignore it, because the gap is only visible from inside,
but I'm not sure what will hapen when I rivet it down. Thanks.
Jesse
N.Smith
Post by N.Smith » Sun Feb 19, 2012 10:34 am
Try a search for "SSL series" or "SEL series"
http://www.skinpins.com/fastmotemp.html
They screw down tightly and provide more grip than spring loaded cleco's
Nig
745E
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com]On Behalf Of Ted
Waltman
Sent: 21 March 2006 20:42
N.Smith
Hi Jesse
around. D'oh
Nig
745E
Jesse Jenks
Thanks Nigel,
Hi Jesse
Nigel
745E
Jesse Jenks
Jesse
Jeff McMurrer
Post by Jeff McMurrer » Sun Feb 19, 2012 10:34 am
Ted,
One source we use is Brown Tools (www.browntool.com) Many types of clecos, <side grip, wedge, etc.>
Grip strength is rated much higher, used for pulling materials together.
Jeff
Date: Tuesday, March 21, 2006 12:42 pm
I did
result. I
