[rebel-builders] Part source...
Post by Wayne G. O'Shea » Sun Feb 19, 2012 10:31 am
O-320 is about 1/4" to 3/8" wider at the exhaust ports than the O-235. I
used the same exhaust I had on my O-235 by sliding the pipes as far out as I
could without them coming apart. Most airplanes that ran the O-235 have a
behind the engine single exhaust "can" like a Super cub/Pa-12 etc. If you
can find one that is slung below the engine (tight under the case in front
of the oil sump) then you may be able to use it.
Sent: Monday, March 06, 2006 8:25 PM
Subject: [rebel-builders] Part source...
Couple of questions...(I am to tired to go in the shop tonight!)
I have a 0-235C1B for my rebel... Is 0-235 and 0-320 have same exaust?
So if I found something that was installed in an airplane with
those engine, I could use the exaust system, with may be some
modification?
Could it be the same for a cowling?
Jean
Rebel 747R
jean.poirier
Post by jean.poirier » Sun Feb 19, 2012 10:31 am
Thanks Wayne,
Just tolet you know that I have bought the prop ofAngus McKenzie
Jean Rebel747R
On Mon Mar 6 21:03 , 'Wayne G. O'Shea' <oifa@irishfield.on.ca> sent:
To: rebel-builders@dcsol.com>
modification?
Jean
Rebel 747R
