Hi Garry,
I had a subscription a couple of years ago. LPM is focused at the certified airplane owner who wants to do as much maintenance as the government will allow. Nothing wrong with that but I did not renew my subscription because I was getting info from Sport Aviation and Kitplanes that was more focused on what I wanted to do (Experimental-Amateur Built). If I owned a certified airplane, I would recommend LPM as well as Aviation Consumer.
Sincerely,
Rich
[rebel-builders] Light Plane Maintenance Subscription
Thanks Rich. I will follow your lead. The propaganda seemed to tilt
toward experimentals as there is a limit to how much you can do with
your own certified. I am in the same boat so no point in learning the
hard way. Cheers
hard way. Cheers
Hi Garry,
Sincerely,
Rich
