Builders,
The frame is riveted fastened sheet aluminium.
what i'm wondering is:
1. What thickness is the sheet alum inside the fuselage that makes up the
circular/rectangular larger sections. The pieces that seperate the bays..
2. Are the solid pieces that run length-wise from each section piece
welded? If so,
by the factory?
