Jesse
Subject: [rebel-builders] Fw: Bending brake
Date: Sat, 18 Feb 2006 07:00:07 -0800
Hi Jesse,
As you can see from below I tried to send some photos as attachments but
got an auto message back from the server saying thats not allowed. If
interested you can send me your personal email address and I can send it
directly to you.
Brian
Sent: Friday, February 17, 2006 6:02 PM
Subject: Re: Bending brake
breakHi Jesse,
Another builder convinced me before I started building that a 3 in 1hourswas a must.
Boy was he ever right. The thing works like a charm and has saved meisof hacking away with a hacksaw, bruised knuckles etc.
Take a look at the attached pictures and note the green stand the unitlevelmounted on. That stand cost extra but was made by the outfit that
manufactured the 3/1 so I bought it, however, as can be seen, if it was
on
the floor the brake would be way too low to work comfortably with .
So, because I needed to raise the unit up to a comfortable workingareand because the unit is so heavy, I got got someone local to build the
grey
stand with wheels. That way I can easily move the thing alone which is a
breeze as the two wheels closest to the camera swivel (the rear wheelscantfixed fore and aft) and can be locked when in the desired position.
In this configuration the unit is rock solid, works like a charm, andthetip over due the the wheel spread.
Hope this helps.
Brian R779
Sent: Saturday, February 18, 2006 2:24 PM
Scott,
Thanks a bunch. I had a feeling that might be the case. I have also
looked
at the combo machines since I want a shear as well. My problem is shop
space. With a 400 pound unit I won't be able to easily move it out ofwhenway. Maybe if I put it on wheels, but It's going to get real crowdedkeepmy
fuselage goes on the gear.
I'm not familiar with how the combo machines, and the real brakes with
fingers work. What would you have to do to the fingers, put a radius on
them? could I do that with hand tools, or would I have to take it to a
machine shop?
Jesse
brake.
