I just place some thin foam between lift and the bottom of the wing surface.
The drywall jack works well since it is on wheels and has a handy wheel that
is turned to crank the wing up and down gently. It makes it easy to align
everything up just right and turns the job into an easy two man operation.
One guy steadies the wing and the other works the jack. There is no lifting
in the somewhat awkward position that is normally required to install and
remove wings when using the arm-strong method. As a result, it is a much
safer and more pleasant task.
Stan
Sent: Sunday, February 19, 2006 5:55 AM
Subject: [rebel-builders] Re: Wing Attach
Stan,
Do you do anything special to the lift or just add padding between the
lift
and the wing?
Brad.
On 2/17/2006 7:00 PM, bearup@ida.net wrote to rebel-builders:
-> Brad,
-> Good observation! I have been using a drywall jack to remove/install
wings
-> on planes for a number of years. A trick that a friend of mine showed
me.
-> ended up purchasing one for myself after renting a few times. They
really
-> work nice.
-> Stan
