M-14 ignition
pollock
M-14 ignition
Post by pollock » Sat Feb 18, 2012 2:53 pm
I received my shower of sparks for my M-9 F mag system.There is no diagram to install it.Does anyone have information on the wiring set up from shower of sparks to the left mag?
Bill
Moose 244
George Coy
M-14 ignition
Post by George Coy » Sat Feb 18, 2012 2:53 pm
Bill,
You need a high tension lead from the top of the shower of sparks unit to
the Left (from pilots view) magneto. Use normal spark plug shielded wire.
Strip the shield from the part that goes into the magneto and the part that
goes into the shower of sparks unit. The gland nut on the magneto metal
cover is where the Shield is terminated. You feed the unshielded part of the
wire through gland nut on the metal cap and then to the phenolic mag cap. .
It goes into the mag cap on the hole that connects with the little tab on
the inside of mag cap. It is usually marked with the Greek letter "PI". The
screw on the inside of the cap needs to be loosened or removed and the wire
inserted. The screw has a point on it so that it pierces the insulation on
the high tension wire and makes electrical contact with the wire core when
you screw it back.
The shower of sparks unit needs to get fed voltage during the time the
start button is depressed only. If you have a Russian unit, then it needs 24
volts. It will not work below about 20 volts. If you have a Bendix unit and
are running it on 12 volts you need to de tune it for 12 volts.
Please feel free to call if you need further help.
George Coy
President
Gesoco Industries Inc.
629 Airport Rd.
Swanton, VT 05488
TEL 802-868-5633
FAX 802-868-4465
Web Site www.gesoco.com
e-mail George@gesoco.com
pollock
Sent: Sunday, February 05, 2006 10:27 AM
Subject: M-14 ignition
Bill
Moose 244
