Rebel: What next?
pequeajim
Rebel: What next?
Post by pequeajim » Sat Feb 18, 2012 2:53 pm
Well, I have my Rebel setup in my garage and some tools together. If you all
recall, this was supposed to be a 90% complete model, but in studying what
has been done, I believe that estimate to be very optimistic.
I went through the manual and this is what I can best figure out what was
done up to this point.
Chapter Title Completed
1. Helpful Hints ---
2. Aileron Assembly X
3. Fabric Covering NS
4. Rudder Assembly X
5. Elevator Assembly 80%
6. Elev-Trim Assembly 80%
7. Elev-Rudder Tip Assembly NS
8. Stabilizer Assembly 90%
9. Fin Assembly 90%
10. Wing Assembly X
11. Wet Tank Assembly X
12. Wing Tip NS
13. Fuselage Assembly X
14. 0320 Fuselage Modifications X
15. Float Hard Point Installation X
16. Spring Gear Assembly X
17. Landing Gear N/A
18. Landing Gear Covering N/A
19. Tailskid X
20. Stabilizer Installation X
21. Wing Struts X
22. Wing Strut Fairings NS
23. ontrol Installation NS
24. Stabilizer Faring Installation NS
25. Seat Assembly 60%
26. Seatbelt Installation NS
27. Door Assembly 70%
28. Door Lock Assembly 40%
29. Wing Fairing Installation NS
30. Windshield Installation N/A
31. Skylight Installation NS
32. Pre-Molded Windshield Installation 25%
33. 912 Cowling N/A
34. 912 Engine Installation N/A
35. O-320 Lycoming Engine Installation 60%
36. O-320 Speed Cowling Installation 60%
37. Ultralight Rudder N/A
38. Ultralight Elevator N/A
Instrument Panel Assembly 35%
The work that is completed thus far is supurb, but there are some
modifications that I will be doing like some of the OMs, and the instrument
panel changes to suite my taste.
It looks like he skipped around quite a bit. I'm sure ther were reasons for
that. I am wondering what I should work on next? In looking at this list,
does it give you guys enough of a clue to offer some suggestions?
Also, I can work in my garage on the aircraft, and by March will have a pole
barn shop completed large enough that I can assemble the complete aircraft
inside and then pull the wings back off before transporting to the airport.
I guess I'm saying that so that you all know that space in not a limitation
once March rolls around.
thanks
Jim!
Rebel #572
Rebel: What next?
Post by Bob Patterson » Sat Feb 18, 2012 2:53 pm
Hi Jim !
Just off the top - looks like finishing up the tail would be a good
place to start. That's a good place to get experience, with smaller parts.
That's where the manual likes to start new builders... then the ailerons.
Check archives for the outer rib & skin reinforcements, and possibly
adding AIL-26 (?) bushings now, rather than later ... don't forget the
POGs (large nylon washers), too !
.......bobp
all recall, this was supposed to be a 90% complete model, but in studying
what has been done, I believe that estimate to be very optimistic.
9. Fin Assembly 90%
10. Wing Assembly X
12. Wing Tip NS
19. Tailskid X
21. Wing Struts X
33. 912 Cowling N/A
instrument panel changes to suite my taste.
for that. I am wondering what I should work on next? In looking at this
list, does it give you guys enough of a clue to offer some suggestions?
pole barn shop completed large enough that I can assemble the complete
aircraft inside and then pull the wings back off before transporting to
the airport.
limitation once March rolls around.
thanks
Jim!
Rebel #572
pequeajim
Rebel: What next?
THanks Bob: I was leaning in that direction as well as cleaning up the panel.
I'll start reading up on the instructions for the tail.
Jim!
-> Hi Jim !
-> Just off the top - looks like finishing up the tail would be a good
-> place to start. That's a good place to get experience, with smaller parts.
-> That's where the manual likes to start new builders... then the ailerons.
-> Check archives for the outer rib & skin reinforcements, and possibly
-> adding AIL-26 (?) bushings now, rather than later ... don't forget the
-> POGs (large nylon washers), too !
-> .......bobp
-> -------------------------------orig.-------------------------
-> On Sunday 29 January 2006 11:00 pm, pequeajim@dcsol.com wrote:
-> > Well, I have my Rebel setup in my garage and some tools together. If
you
-> > all recall, this was supposed to be a 90% complete model, but in studying
-> > what has been done, I believe that estimate to be very optimistic.
-> > I went through the manual and this is what I can best figure out what
was
-> > done up to this point.
-> > Chapter Title Completed
-> > 1. Helpful Hints ---
-> > 2. Aileron Assembly X
-> > 3. Fabric Covering NS
-> > 4. Rudder Assembly X
-> > 5. Elevator Assembly 80%
-> > 6. Elev-Trim Assembly 80%
-> > 7. Elev-Rudder Tip Assembly NS
-> > 8. Stabilizer Assembly 90%
-> > 9. Fin Assembly 90%
-> > 10. Wing Assembly X
-> > 11. Wet Tank Assembly X
-> > 12. Wing Tip NS
-> > 13. Fuselage Assembly X
-> > 14. 0320 Fuselage Modifications X
-> > 15. Float Hard Point Installation X
-> > 16. Spring Gear Assembly X
-> > 17. Landing Gear N/A
-> > 18. Landing Gear Covering N/A
-> > 19. Tailskid X
-> > 20. Stabilizer Installation X
-> > 21. Wing Struts X
-> > 22. Wing Strut Fairings NS
-> > 23. ontrol Installation NS
-> > 24. Stabilizer Faring Installation NS
-> > 25. Seat Assembly 60%
-> > 26. Seatbelt Installation NS
-> > 27. Door Assembly 70%
-> > 28. Door Lock Assembly 40%
-> > 29. Wing Fairing Installation NS
-> > 30. Windshield Installation N/A
-> > 31. Skylight Installation NS
-> > 32. Pre-Molded Windshield Installation 25%
-> > 33. 912 Cowling N/A
-> > 34. 912 Engine Installation N/A
-> > 35. O-320 Lycoming Engine Installation 60%
-> > 36. O-320 Speed Cowling Installation 60%
-> > 37. Ultralight Rudder N/A
-> > 38. Ultralight Elevator N/A
-> > Instrument Panel Assembly 35%
-> > The work that is completed thus far is supurb, but there are some
-> > modifications that I will be doing like some of the OMs, and the
-> > instrument panel changes to suite my taste.
-> > It looks like he skipped around quite a bit. I'm sure ther were reasons
-> > for that. I am wondering what I should work on next? In looking at this
-> > list, does it give you guys enough of a clue to offer some suggestions?
-> > Also, I can work in my garage on the aircraft, and by March will have a
-> > pole barn shop completed large enough that I can assemble the complete
-> > aircraft inside and then pull the wings back off before transporting to
-> > the airport.
-> > I guess I'm saying that so that you all know that space in not a
-> > limitation once March rolls around.
-> > thanks
-> > Jim!
-> > Rebel #572
-> > List archives located at: https://www.dcsol.com/login
Rebel: What next?
Post by Ken » Sat Feb 18, 2012 2:53 pm
And then the wheels so it can be moved?
Perhaps one bushing at the lower rudder pivot is sufficient? There
wasn't a lot of meat on that bracket so since I have access to a lathe I
lightly pressed a smaller diameter bushing in instead of an AIL-26.
Outer rib reinforcements on elevator only not the rudder.
I timed the fabric and paint for the Fall when the temperature was
reasonable and bugs were low, but pick up the chemicals if you drive by
anywhere (OSK, Sun'n fun, etc,?) that has them.
Bob Patterson wrote:
Hi Jim !
.......bobp
9. Fin Assembly 90%
10. Wing Assembly X
12. Wing Tip NS
19. Tailskid X
21. Wing Struts X
33. 912 Cowling N/A
the airport.
thanks
Jim!
Rebel #572
Robert and Olga Johnson
Rebel: What next?
Post by Robert and Olga Johnson » Sat Feb 18, 2012 2:53 pm
Hi Jim: My suggestion would be to start at the beginning of the manual,
completing what you can do as you go along. Keep in mind of course the
pre-closure inspection - if your in Canada that is. I would strongly suggest
you also locate and match up all the hardware necessary for each area at
final assembly. The Rebel I am helping with at this time has been very short
coming in this area. This would give you time to order the missing items
before you actually need them. Work with the manual on hardware inventory as
we found we had everything according to the shipping documents, its just
that a lot of necessary items where not listed. Have fun, it is a great
airplane. Bob J
Sent: Sunday, January 29, 2006 11:00 PM
Subject: Rebel: What next?
pequeajim
Rebel: What next?
I thought about that but I am worried that in some cases there are steps
that should be held off until other steps are completed.
Can you guys tell me; for a 1997 Rebel #572, can you build the aircraft
following the manual from step one all the way through to the end? Is
Murphy's building sequence correct?
Jim!
On 1/30/2006 4:31 AM, rjohnson18@cogeco.ca wrote to rebel-builders:
-> Hi Jim: My suggestion would be to start at the beginning of the manual,
-> completing what you can do as you go along. Keep in mind of course the
-> pre-closure inspection - if your in Canada that is. I would strongly suggest
-> you also locate and match up all the hardware necessary for each area at
-> final assembly. The Rebel I am helping with at this time has been very
short
-> coming in this area. This would give you time to order the missing items
-> before you actually need them. Work with the manual on hardware
inventory as
-> we found we had everything according to the shipping documents, its just
-> that a lot of necessary items where not listed. Have fun, it is a great
-> airplane. Bob J
-> From: <pequeajim@dcsol.com>
-> Sent: Sunday, January 29, 2006 11:00 PM
-> Subject: Rebel: What next?
John Kramer
Rebel: What next?
Post by John Kramer » Sat Feb 18, 2012 2:53 pm
Jim,
I don't know anything about building airplanes but, I can guarantee
if you try and strictly follow, either the new or the old, manual
STEP BY STEP you will screw up.
John...
Jim!
strongly suggest
short
inventory as
-> airplane. Bob J
Fly too low or too slow and the ground will rise up and smite thee.
pequeajim
Rebel: What next?
I'm a little worried about that. Bob P's suggestion is probably that best one
that this point. This is an easier area to work on and will get me acclimated,
(did I spell that right?), before I move on to the other areas.
On 1/30/2006 6:58 PM, 369r@kramers.org wrote to rebel-builders:
-> Jim,
-> I don't know anything about building airplanes but, I can guarantee
-> if you try and strictly follow, either the new or the old, manual
-> STEP BY STEP you will screw up.
-> John...
-> At 09:14 PM 01/30/06, pequeajim@dcsol.com wrote:
-> >I thought about that but I am worried that in some cases there are steps
-> >that should be held off until other steps are completed.
-> >Can you guys tell me; for a 1997 Rebel #572, can you build the aircraft
-> >following the manual from step one all the way through to the end? Is
-> >Murphy's building sequence correct?
-> >Jim!
-> >On 1/30/2006 4:31 AM, rjohnson18@cogeco.ca wrote to rebel-builders:
-> >-> Hi Jim: My suggestion would be to start at the beginning of the
manual,
-> >-> completing what you can do as you go along. Keep in mind of course
-> >-> pre-closure inspection - if your in Canada that is. I would
-> >strongly suggest
-> >-> you also locate and match up all the hardware necessary for each
area at
-> >-> final assembly. The Rebel I am helping with at this time has been very
-> >short
-> >-> coming in this area. This would give you time to order the missing
items
-> >-> before you actually need them. Work with the manual on hardware
-> >inventory as
-> >-> we found we had everything according to the shipping documents, its
just
-> >-> that a lot of necessary items where not listed. Have fun, it is a great
-> >-> airplane. Bob J
-> >-> ----- Original Message -----
-> >-> From: <pequeajim@dcsol.com>
-> >-> To: <rebel-builders@dcsol.com>
-> >-> Sent: Sunday, January 29, 2006 11:00 PM
-> >-> Subject: Rebel: What next?
-> Fly too low or too slow and the ground will rise up and smite thee.
Rebel: What next?
Post by Mike Davis » Sat Feb 18, 2012 2:53 pm
Boy, that was a good laugh. NO, you can not follow the manual step by step
without running into problems. Sorry, but it's just not that straight
forward. Pic a part, read the entire chapter relating to that part, make
some notes as to what goes where when, highlight steps in the manual that
would be better done at a later point, ask questions on the list if you're
not sure. That's the best any of us can do.
Sent: Monday, January 30, 2006 6:14 PM
Subject: Re: Rebel: What next?
Jim!
suggest
at
short
items
inventory as
just
-> airplane. Bob J
