Rebel spring gear weight - brakes
Post by Bob Patterson » Sat Feb 18, 2012 2:45 pm
Glad you both have enough brake - I was remembering the ORIGINAL
gold Matco's on FINR. They would not hold the 912 above about 3,000 RPM,
on a good day !!! The later gold Matco's had better brakes - wasn't
sure how old John's were ....
On Thursday 19 January 2006 07:58 pm, Wayne G. O'Shea wrote:
Was ed zakery my point Garry.....when you get to my post! :O)Wayne
To: "rebel builders" <rebel-builders@dcsol.com>
Sent: Thursday, January 19, 2006 7:54 PM
Subject: Re: Rebel spring gear weight
I'm not entirely sure more braking is wise. FOKM has the old Matco gold
colored wheels with the small brakes and I can lift the tail up with
hard braking on pavement. How much more would one really want? Why?
On Thu, 2006-19-01 at 14:44 -0500, Bob Patterson wrote:
Hi John !
Matco make a silver wheel that has much better braking - only
a bit heavier..... or maybe the silver wheel brakes could be
fitted....
The Rotec engines do look good, especially on a Renegade,
BUT - they are a LOT heavier -- in the 220 - 240 lb range,
vs about 158 for a complete installed 912, with oil & coolant...
I'm with you on the Jabirus - still old air-cooled technology,
and they are also heavier than the 912, for less power...
On Thursday 19 January 2006 12:40 pm, John Kramer wrote:
time
turns
I'm
why
my
I'm
cleco
one's
tempting
have
lb.
https://ssl.perfora.net/gs-air.com/sess ... 43b2bd350d
depending
FUS-30
you
Also,
help
ground.
Post by Wayne G. O'Shea » Sat Feb 18, 2012 2:45 pm
Maybe on the AULA 5/8" diameter axle ones. They have smaller brake
pads...but I've never used them. Always stepped up to the 3/4 axle and the
normal 3 rivet 66-106 pads. If anyone is playing with Ultralights I have two
sets of the 5/8" diameter axle Matco's here in brand new condition.
Sent: Thursday, January 19, 2006 8:41 PM
Subject: Re: Rebel spring gear weight - brakes
gold
previous
way
chapter
time
turns
at
3,
mount
it
list.
I'm
why
my
I'm
cleco
one's
tempting
have
13
lb.
you
Sebring -
if
you
Also,
help
ground.
thee.
