fuel flow test
fuel flow test
Post by Ralph Baker » Sat Feb 18, 2012 2:36 pm
If I remember, the required test is to have the airplane in flight attitude and show that the system, at the carburetor, will flow 50% of the maximum power fuel flow. To be conservative, I would test with minimum fuel in the tank and also at maximum expected climb angle which diminishes the pressure head above the carb. Best to determine adequate flow on the ground rather than determine insufficient flow in the air.
mbetti
fuel flow test
Post by mbetti » Sat Feb 18, 2012 2:36 pm
I've never heard of this test, is it required in US? What kind of device required to do it? Is it a tool or something that stays on the plane?
Mike Betti
771E
Robert and Olga Johnson
fuel flow test
Post by Robert and Olga Johnson » Sat Feb 18, 2012 2:36 pm
Mike: In Canada a fuel flow test is required prior to final inspection and
must produce 150% of fuel required for maximum take off consumption if it is
a gravity feed system and 125% if using fuel pumps. This test is easy to do
by simply disconnecting the fuel line just before the carb, open the fuel
cocks and collect fuel for one minute. Multiply by 60 and you have your
hourly fuel flow. The only device you need is a measuring cup and a
calculator. Hope this helps. - Bob J
Sent: Thursday, December 29, 2005 2:26 PM
Subject: Re: fuel flow test
Mike Betti
771E
Jeff McMurrer
fuel flow test
Post by Jeff McMurrer » Sat Feb 18, 2012 2:36 pm
At the same time your doing fuel flow test, you can figure out what your UNUSABLE fuel will be. Just something else you might want to know.
Jeff
From: Robert and Olga Johnson <rjohnson18@cogeco.ca>
Date: Thursday, December 29, 2005 12:06 pm
inspection and
easy to do
the fuel
your
of device
plane?> Thanks,
Mike Betti
771E
mbetti
fuel flow test
Ok thanks for the replies,
I was hoping I didn't have to add another piece of hardware to my panel, it's full now!
Mike Betti
771E
Jeff
inspection and
easy to do
the fuel
your
of device
plane?> Thanks,
Mike Betti
771E
fuel flow test
Post by Ken » Sat Feb 18, 2012 2:36 pm
Don't forget to put the aircraft in the max climbing attitude and I'd
recommend a LARGE measuring cup or just time how long it takes to fill a
gallon or half gallon can ;)
jimsrebel
fuel flow test
Post by jimsrebel » Sat Feb 18, 2012 2:37 pm
If your Carb has a drain plug in the float bowl, remove drain plug and check
the flow rate at this point. This will also test the flow rate through the
needle and seat. If you have a freshly overhauled Carb using the input fuel
line will still be a safe bet, but a lot of the engines that find their way
onto a homebuilt have been stored for a long time. Plus it will never hurt to
flush out the carb real good before you fly it.
Jim L.
On 12/29/2005 11:06 AM, rjohnson18@cogeco.ca wrote to rebel-builders:
-> Mike: In Canada a fuel flow test is required prior to final inspection and
-> must produce 150% of fuel required for maximum take off consumption if it
is
-> a gravity feed system and 125% if using fuel pumps. This test is easy to
do
-> by simply disconnecting the fuel line just before the carb, open the fuel
-> cocks and collect fuel for one minute. Multiply by 60 and you have your
-> hourly fuel flow. The only device you need is a measuring cup and a
-> calculator. Hope this helps. - Bob J
-> From: <mbetti@up.net>
-> Sent: Thursday, December 29, 2005 2:26 PM
-> Subject: Re: fuel flow test
-> > I've never heard of this test, is it required in US? What kind of device
-> > required to do it? Is it a tool or something that stays on the plane?
-> > Thanks,
-> > Mike Betti
-> > 771E
steve whitenect
fuel flow test
Post by steve whitenect » Sat Feb 18, 2012 2:37 pm
I also understand that the inlet fitting that has the small filter screen
must be attached to the fuel line and be held in the exact area or level
where it threads into the carb.
Steve W.
Date: Thu, 29 Dec 2005 13:57:09 -0900
check
Jim L.
it
is
do
fuel
device
-> > Thanks,
-> > Mike Betti
-> > 771E
Alan Hepburn
fuel flow test
Post by Alan Hepburn » Sat Feb 18, 2012 2:37 pm
Mike:
You'll find the report form on the MD-RA website.
