I know I already touched this subject. Do I have to go through the rear solid bulkhead, the one the fin is attached to with my rudder cable? And, does anyone have a pic where they may have used pulleys to make the cable bend behind the cabin area? I would like to see how this fits near the mixer assembly on the pilots side.
Mike Betti
771E
Rudder fairleads
Rudder fairleads
I'll get you some shots when I can Mike. Had to put our Lab down today...so
not in the mood for going in the hangar tonight without the patter of 4 feet
to greet me.
Sent: Monday, December 19, 2005 9:11 PM
Subject: Rudder fairleads
to greet me.
solid bulkhead, the one the fin is attached to with my rudder cable? And,I know I already touched this subject. Do I have to go through the rear
Mike Betti
771E
Rudder fairleads
Mike, I'll and try and corner one of my boys with his camera this evening
and get some pics for u. I used the round two piece fairleads and had no
trouble getting around the mixer ass.
Steve W.
Steve W.
Date: Mon, 19 Dec 2005 20:11:40 -0600
Mike Betti
771E
Rudder fairleads
Pics on the cabin to cone transition pulley on their way direct Mike. Will
post them up to the list as well.
Sent: Monday, December 19, 2005 9:20 PM
Subject: Re: Rudder fairleads
today...soI'll get you some shots when I can Mike. Had to put our Lab down
feetnot in the mood for going in the hangar tonight without the patter of 4
mixerto greet me.
assembly on the pilots side.Thanks,
Mike Betti
771E
Rudder fairleads
Mike, on going through these bulkheads, yes you do. I liked somebody's idea
about using a laser pointer and a plastic dummy bulkhead to align the holes,
but I had the permaent bulkhead already in place before I takled this
problem. There's no perfect alignment, beacuse movement of the rudder horn
attach point means that the cable is always going to be dragging sideways on
the most aft fairlead at some point in its travel, unless the holes in the
bulkhead and fuselage side are enormous. I actually wound up placing a
fairlead at the aft end of the slot through the fuselage skin to keep things
aligned. I'd prefer less fairleads as there's quite a bit of drag in the
system, especially with water rudders added.
