Stab install
mbetti
Stab install
Post by mbetti » Sat Feb 18, 2012 2:33 pm
Eliteists,
I'm finding it hard to get the stab and elevator mounted with out scatching and damaging it. I have a helper too. Seems the trouble comes in after the two pieces are in but trying to get the center hinge mated. I already put a couple small dents in the leading edge where it would be up against the front rudder attach bracket, at least hidden by fairing. I don't know how I'm going to ever keep the paint on it when the times comes. An extra 1/4" would be the answer. Any tricks.
Mike Betti
771E
Alan Hepburn
Stab install
Post by Alan Hepburn » Sat Feb 18, 2012 2:33 pm
Mike:
It is pretty tight. But if you use Wayne's idea and secure at least the rear
attach brackets to the fuselage wioth captive nuts inside the fuselage
instead of plain vanilla bolts an nuts, you can leave out these brackets
until after the stab and elevator are in position. Another bonus is that
you can shim the stab to adjust its incidence without removing everything.
You are going to have to remove that stab at least once to paint the area
around the hinge line. I took mine off for painting, and was suggesting
only painting the hinge area before re-assembly, but with that rear bracket
removed it should go much easier. Look at it and let me know what you
think.
Al
Mike Betti
Stab install
Post by Mike Betti » Sat Feb 18, 2012 2:33 pm
Thanks Al,
I'm not sure.................. As you bring the elevator down to a lower
point in that space, you loose more space due to the curved rear rudder
attach spars. Have you tried it? Are you still fighting with it with your
rear attach brackets removed?
I like the idea of painting the hinge line and then reassembling.
Mike Betti
771E
Sent: Monday, December 19, 2005 5:44 PM
Subject: Re: Stab install
Mike:
rear
bracket
think.
Al
Mike Betti
Stab install
Al,
How about cutting off the fin front spar edges, see pic? Do you think that
would help. I don't know about affecting it structurally by doing this?
www.mikeselite.com/images/stabclearance.jpg
Mike Betti
771E
Mike:
rear
bracket
think.
Al
Alan Hepburn
Stab install
You may be right, Mike. My airplane is down at the paint shop, so I can't
try it. That's why I was hoping you'd be able to investigate. When you
install the thing, the elevator is leading edge down, and the stab is
trailing edge down. I know when took it off for painting, we convinced
ourselves that with that bracket out we'd be able to install it without too
much risk of damage. We'd still stick some protective tape on the stab LE,
however.
Al
mbetti
Stab install
I'm going to cut the fin spar and try the stab install this weekend hopefully.
Mike Betti
however.
Al
Stab install
Post by Bob Patterson » Sat Feb 18, 2012 2:33 pm
Whoa Mike !!
I'm no engineer, but a mod like that DEFINITELY should be
run past the factory !! Could significantly weaken the structure !
(or not ... IANAE ! ;-) )
On Tuesday 20 December 2005 08:49 pm, Mike Betti wrote:
Al,
Mike Betti
771E
Mike:
rear
that
everything.
area
bracket
think.
Al
Alan Hepburn
Stab install
Post by Alan Hepburn » Sat Feb 18, 2012 2:36 pm
Mike:
A-a-a-rrr-kk! It isn't that tough do do it! Practice a few times and it
goes farly smoothly. I must have had mine in and out 4 or 5 times by now.
(For those who have less than pure minds and have not been following this
Email trail, it should be pointed out that we are talking about the
"Subject", on the Elite). You do need a couple of people and you certainly
might scuff the paint, but the most that should need to be done is to paint
the leading edge after installation. If you factor that into your paint
scheme design, it would be a non-issue.
No doubt a design that allowed for later attachment of the fin with
removable fasteners would have been better, but don't go cutting the spar
until you have designed how you're going to re-attach it.
Al
