Main Solenoid
steve whitenect
Main Solenoid
Post by steve whitenect » Sat Feb 18, 2012 2:33 pm
That's why u don't have to fuse the wire to it!
Steve W.
Subject: RE: Main Solenoid
Date: Thu, 15 Dec 2005 09:16:16 -0900
You are right. I don't know what the heck I was thinking. That is the way
the previous owner described it to me and I just took it for face value.
There is a small terminal on the solenoid that completes the circuit and
activates it.
I saw the stinkin thing, but it just did nto click until after I was at
work
today.
Thanks for the response.
Jim!
On 12/15/2005 8:50 AM, admin@airnig.co.uk wrote to rebel-builders:
-> Hi Jim
-> I think it should be OK volts wise, but one thing that surprised me was
that
-> the small connection goes to ground to activate the solenoid, not have
12v
-> applied to it !
-> Nigel
-> 745E
-> -----Original Message-----
-> From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com]On Behalf Of
-> pequeajim@dcsol.com
-> Sent: 15 December 2005 12:23
-> Subject: REB: Main Solenoid
-> I decided to hook up power to my Rebel last night. I have a small
portable
-> starter battery that I use for my RC stuff and starting cars in the
winter
-> if
-> their battery is dead.
-> After connecting everything up, I flipped the master switch and nothing?
-> Does this solenoid need a certain amperage battery to toggle when turing
-> master switch?
-> List archives located at: https://www.dcsol.com/login
-> Subscription services located at:
-> https://www.dcsol.com/public/code/html-subscribe.htm
N.Smith
Main Solenoid
Post by N.Smith » Sat Feb 18, 2012 2:33 pm
Hi Jim
I think it should be OK volts wise, but one thing that surprised me was that
the small connection goes to ground to activate the solenoid, not have 12v
applied to it !
Nigel
745E
pequeajim@dcsol.com
I decided to hook up power to my Rebel last night. I have a small portable
starter battery that I use for my RC stuff and starting cars in the winter
if
Does this solenoid need a certain amperage battery to toggle when turing the
master switch?
pequeajim
Main Solenoid
Post by pequeajim » Sat Feb 18, 2012 2:33 pm
activates it.
I saw the stinkin thing, but it just did nto click until after I was at work
today.
Jim!
-> Hi Jim
that
-> the small connection goes to ground to activate the solenoid, not have 12v
-> applied to it !
-> Nigel
-> 745E
-> I decided to hook up power to my Rebel last night. I have a small portable
-> starter battery that I use for my RC stuff and starting cars in the winter
-> if
-> master switch?
Main Solenoid
Post by Wayne G. O'Shea » Sat Feb 18, 2012 2:33 pm
Uses ground so no live wires enter the circuit to the master switch and
back...to make it work. A proper Master solenoid picks up the + internally
from the battery terminal on one side of the case. Make sure you are
connecting to the right one. If unsure...put a meter on the small terminal
and then each big stud. The one that gives you a circuit is the large stud
that the battery gets connected to and the other large stud heads for your
starter solenoid and buss bar for the Circuit Breakers.
Sent: Thursday, December 15, 2005 1:16 PM
way
activates it.
work
today.
Jim!
-> Hi Jim
that
12v
-> applied to it !
-> Nigel
-> 745E
portable
winter
-> if
nothing?
turing
-> master switch?
pequeajim
Main Solenoid
Got it thanks. Fired up all the electronics tonight!
Now I need to find a good airspeed indicator, VOR, and then artificial
horizon...
On 12/15/2005 12:38 PM, oifa@irishfield.on.ca wrote to rebel-builders:
-> Uses ground so no live wires enter the circuit to the master switch and
-> back...to make it work. A proper Master solenoid picks up the + internally
-> from the battery terminal on one side of the case. Make sure you are
-> connecting to the right one. If unsure...put a meter on the small terminal
-> and then each big stud. The one that gives you a circuit is the large stud
-> that the battery gets connected to and the other large stud heads for your
-> starter solenoid and buss bar for the Circuit Breakers.
-> Wayne
-> From: <pequeajim@dcsol.com>
-> Sent: Thursday, December 15, 2005 1:16 PM
-> Subject: RE: Main Solenoid
-> > You are right. I don't know what the heck I was thinking. That is the
-> way
-> > the previous owner described it to me and I just took it for face value.
-> > There is a small terminal on the solenoid that completes the circuit and
-> > activates it.
-> > I saw the stinkin thing, but it just did nto click until after I was at
-> work
-> > today.
-> > Thanks for the response.
-> > Jim!
-> > On 12/15/2005 8:50 AM, admin@airnig.co.uk wrote to rebel-builders:
-> > -> Hi Jim
-> > -> I think it should be OK volts wise, but one thing that surprised me was
-> > that
-> > -> the small connection goes to ground to activate the solenoid, not have
-> 12v
-> > -> applied to it !
-> > -> Nigel
-> > -> 745E
-> > -> -----Original Message-----
-> > -> From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com]On Behalf Of
-> > -> pequeajim@dcsol.com
-> > -> Sent: 15 December 2005 12:23
-> > -> To: rebel-builders@dcsol.com
-> > -> Subject: REB: Main Solenoid
-> > -> I decided to hook up power to my Rebel last night. I have a small
-> portable
-> > -> starter battery that I use for my RC stuff and starting cars in the
-> winter
-> > -> if
-> > -> their battery is dead.
-> > -> After connecting everything up, I flipped the master switch and
-> nothing?
-> > -> Does this solenoid need a certain amperage battery to toggle when
-> turing
-> > the
-> > -> master switch?
-> > -> List archives located at: https://www.dcsol.com/login
-> > -> username "rebel" password "builder"
-> > -> Subscription services located at:
-> > -> https://www.dcsol.com/public/code/html-subscribe.htm
-> > -> List administrator: mike.davis@dcsol.com
-> > List archives located at: https://www.dcsol.com/login
Main Solenoid
Buy the cheapest A/S you can find. It won't be accurate anyhow due to the
inability to find a good static point on the Rebel. All that matters if
reference to stall...number showing is incidental.
As for VOR...do you use it for anything these days?..other than listening to
Country and Western?
A/H - the offshore $359US versions from Aircraft Spruce seem to last just as
well as the RC Allens
Sent: Thursday, December 15, 2005 8:20 PM
Subject: Re: Main Solenoid
horizon...
internally
terminal
stud
your
-> Wayne
-> way
value.
-> > activates it.
at
-> work
-> > today.
-> > Jim!
-> > -> Hi Jim
me was
-> > that
have
-> 12v
-> > -> Nigel
-> > -> 745E
Of
-> portable
-> winter
-> > -> if
-> nothing?
-> turing
-> > the
Main Solenoid
Post by Mike Kimball » Sat Feb 18, 2012 2:33 pm
You must mean ADF, not VOR, eh Wayne?
G. O'Shea
Sent: Thursday, December 15, 2005 4:26 PM
horizon...
internally
terminal
stud
your
-> Wayne
-> way
value.
-> > activates it.
at
-> work
-> > today.
-> > Jim!
-> > -> Hi Jim
me was
-> > that
have
-> 12v
-> > -> Nigel
-> > -> 745E
Of
-> portable
-> winter
-> > -> if
-> nothing?
-> turing
-> > the
Main Solenoid
Post by Drew Dalgleish » Sat Feb 18, 2012 2:33 pm
If I was doing my panel now i'd want something like this.
http://www.dynonavionics.com/
instead of a bunch of steam gauges
horizon...
Main Solenoid
Yah I do...same obsolete technology! LOL
Sent: Thursday, December 15, 2005 10:21 PM
G. O'Shea
as
horizon...
internally
terminal
stud
your
-> Wayne
-> way
value.
circuit
-> > activates it.
was
at
-> work
-> > today.
-> > Jim!
-> > -> Hi Jim
me was
-> > that
not
have
-> 12v
-> > -> Nigel
-> > -> 745E
Behalf
Of
small
-> portable
-> winter
-> > -> if
-> nothing?
when
-> turing
-> > the
