FLAP MOD
FLAP MOD
Post by Wayne G. O'Shea » Fri Feb 17, 2012 5:38 pm
Your following message has been delivered to the 134 members of
the list murphy-rebel@dcsol.com at 20:45:39 on 1 Dec 1999.
Allister, Hard to compare apples to apples as mine that I just switched to
the O-320, has the old Piper bowl style cowl and the new one has the speed
cowl. Also mine has a warp drive prop and the new one a brand new
Sensenich. Both the Warp prop and the blunt cowl create more frontal drag in
a glide, so it's easier to slow the plane down, than the one with the speed
cowling. I regularly land and stop(no wind), in less than 300 feet with full
flaps. I never use full flaps for take off, only 8 degrees on wheels and 16
degrees on skis. Even on wheel skis I got off the ground with my 100Hp in
500 feet in deep powder snow. I now get off the ground in about 250 feet
with the 150hp on wheels.(and climb about 2000FPM at 1350lb) I can now go in
and out of my Mothers back farm field(about 450 feet fence rail to fence
rail) instead of Her having to drive to the airport to get me.(I used to be
able to get in, just not out)
Date: Wednesday, December 01, 1999 8:10 PM
Subject: FLAP MOD
Wayne, thanks for your feedback, the question I forgot to ask was,
ofcourse,
What sort of increase to the takeoff and land performance have you got by
using the direct linkage to your flaperons vs. the cable version?
Alister
Date: Thursday, December 02, 1999 10:46 AM
Subject: Re: FIREWALL PICTURES/FLAP MOD
Allister (and all), I've never had a problem slowing down into the flap
speed range, as with a 100HP O-235 I was usually in it already!!!!! Now
that
I have the 150 on the nose I will have to be a little more careful. The
last
couple weeks I have been flying both 150 hp Rebels, one for an hour and
then
the next, flying off a voluntary 25 hours passenger free, on both aircraft
with their new engines. (wife can replace me, but not our children!) I
find
the one with the teleflex cable can be flown around the circuit quite
easily
with full flaps down and no real need for the rudder pedals. This is
largely
because the 23degree ground setting looks like about 10(or less) when in
air (even as I cross the fence at 45MPH). Mine with the mechanical hook
up,
on the other hand has never flown a circuit without use of the rudder
pedals
to get you around the corners. I only select full flap, when lined up for
short final(and not on gusty days) because the only way it will turn with
full flaps selected is to kick it in the direction you want to go with the
rudder! Again mine are set 23 degrees max. down static and probably flex
up
to about 18 degrees at 60MPH. Note that the torque tube horns flex also,
not
just the cable! And remember, any flaperoned aircraft is usually led with
rudder and then flaperon in the turns! If you don't you will find you are
turning left and then need right stick to maintain the left turn! This is
especially true in a Kitfox or CH701! This is why alot of people split the
flaps, because they want it to fly like a Cessna, but in return they lose
most of the roll rate and half their flaps(because you can't put them down
any farther with out some extra hinges or reinforcement!) which increases
their obstacle clearance considerably! There is nothing more impressive to
observers than watching a Rebel fly over and then down the side of a tree,
landing pretty much at it's base! It's a pretty neat ride from the cockpit
also! (isn't it Bob and others that have learned how to make this great
plane do what it was designed to do!(and then some))
Murphy's answer to any mod is don't do it! This is strictly a liability
issue on Darryl's part and you can't blame him at all for that!!!!!!(he
has
busted his ass for 14+ years, to get Murphy where it is and it's not worth
losing everything over someone's botched modification!) The two hinges are
more than enough to take the load at 23 degrees within the flap speed
range.
(they don't blow off at 130 either and don't ask how I know!) Most
non-structural and cosmetic mods are pretty safe for anyone to do.
Structural items on the other hand, like wing extensions etc., you had
better know what you are doing and how to do the load calculations. I
looked
at adding 3 feet to each wing, similar to the 18" art wing extensions for
Cessna 185, but when I did the math, I didn't like the numbers and scraped
the idea.(besides, the extra 50HP has since fixed the climb rate anyway!)
Wing tips also seem to be getting longer and longer, and sooner or later
(if
they get any longer) someone is going to buckle up a wing. (this happened
with some Cessna's using the ART wing extension, and in hindsight they
found
not all wings had a required stiffener in them.) So everyone, please make
sure you know what you are doing, before you do it outside the scope of
manual!
Enough rambling from me, (Allister)I've got to get down and over to your
great country one day! Looked at flying the outback tour once, but
couldn't
find the time!(would have to be a month minimum to make it worth while I
think!)
Blue Skies and Tailwinds, Wayne
Date: Wednesday, December 01, 1999 2:35 PM
Wayne hi,
Thanks for the reply, the 63 thou plates should be heavy enough! I have
incorporated 32 thou plates and the Murphy mod, also done something
similar
to you and placed a channel under the 'bathtub' top engine mount back to
witches hat on the sidewall and enlarged the doubler and placed on the
outside.
I was interested in your mod in placing a mechanical linkage onto the
flaperon. It seems at first glance to be a good idea when you look at the
amount of flex in the cable supplied. ( you're not talking just a few
degrees here, you seem to lose at least half your flaperon deflection as
soon as you rotate.)
I would be interested in your feedback on a couple of points.
Firstly, even with the reduced deflection because of the cable flexing
aircraft takes on a completely different set of characteristics in
relation
to adverse yaw, with a mechanical linkage presumably using the full 18
degrees how do you find the handling of the aircraft in this area.
Secondly, I contacted Murphy in regard to possibly doing a mod along
these
lines, their comments suggested that flex in the cable is a great safety
device, it is almost impossible to stress this area because the higher
loading the more the cable flexes, even if you exceed the flap speed it
is
not such a big drama.
Any comments?
Did you add more flaperon hinge points when you did you mod?
Alister
Date: Thursday, December 02, 1999 7:05 AM
forget
matter
perimeter
sheet
have
Rebels!
though,
it
that
Flaps!
Rebel.
No the
Cessna's
if
his
flying
doubler
? fun
mount
Alister Yeoman
FLAP MOD
Post by Alister Yeoman » Fri Feb 17, 2012 5:38 pm
Wayne, thanks for your feedback, the question I forgot to ask was, ofcourse,
Alister
that
last
then
find
easily
largely
air (even as I cross the fence at 45MPH). Mine with the mechanical hook up,
pedals
rudder! Again mine are set 23 degrees max. down static and probably flex up
not
issue on Darryl's part and you can't blame him at all for that!!!!!!(he has
range.
looked
at adding 3 feet to each wing, similar to the 18" art wing extensions for a
(if
found
sure you know what you are doing, before you do it outside the scope of the
manual!
great country one day! Looked at flying the outback tour once, but couldn't
think!)
Wayne hi,
similar
outside.
Firstly, even with the reduced deflection because of the cable flexing the
relation
Secondly, I contacted Murphy in regard to possibly doing a mod along these
device, it is almost impossible to stress this area because the higher the
loading the more the cable flexes, even if you exceed the flap speed it is
Any comments?
Alister
Ken, not sure what double row of rivets you are talking about! I did
forget
in my e-mail to Allister yesterday, that I build every aircraft, no
matter
what engine goes on, with a double "stagered" row of rivets up the door
post. If you are talking about the line of rivets going around the
perimeter
of the firewall, this firewall was done by the previous owner with a
sheet
of stainless riveted over top of the original aluminum. And YES you are
right this aircraft and its Mods are like Lays Potato Chips!(you can't
have
just one) In my case thats true for both the Mods and the number of
Rebels!
My #1 personal Rebel has aluminum flaperons(counter balanced), flaps on
floor(totally mechanically linked to get rid of the play and flex of
teleflex cable), 4 fully adjustable seats, etc. etc. etc. Over time
though,
most of these novelties wear off and you will wish you had of just built
it
by the book and been enjoying the flight characteristics of the craft,
that
much sooner. If I may be Bold, one mod I absolutely hate is Electric
Flaps!
Couldn't stand them in a newer model Cessna, can't stand them in a Rebel.
No
two landings are ever the same with electric flaps because you can't get
same position at the swing of a lever! This is the main reason 185
Cessna's
are the prefered Cessna on floats, because of their manual flaps! Sorry
if
offended anyone with this mod already completed, but I watch a gentleman
with this Mod in his Rebel, spend most of his flight time playing with
his
Electric flap switch, trying to get them in the right place!(and not
flying
the aircraft!)
To: (Murphy Rebel Builders List) <murphy-rebel@dcsol.com>
Date: Wednesday, December 01, 1999 8:38 AM
would be
doubler
fun
eh! from *----------------------------------------------------*
