What Wayne is saying is that the torque you read on the torque wrench is composed of the sum of the nylon insert totque and the metal nut / bolt torque. The torque tables only account for the nut / bolt torque (no self locking). Therefore, clamp a bolt lightly in your vise, run a nut on until the bolt just protrudes, and by starting at zero slowly up the torque value set on the wrench until the nut just begins to turn. That is the value the nut alone requires to turn.
Then add that value to the torque value for the bolt from the table and use the resulting sum as the set value on the torque wrench for assembly tightening. Of course, that only is valid for the first time the nut sees the bolt.
All that said, I'm going to bolt out of here before going nuts.
nyloc nut torques
nyloc nut torques
Thanks Terry, Ralph. I have assumed that the torque ratings were meant for
the twist strain limit of the bolt itself, and that adding anything to torque
ratings was improper. (I've twisted bolts to failure in non-aircraft hack
mechanic mode, but cannot recall ever breaking or stripping any nuts, thus,
still surprised to hear about adding torque for the nylock.) I can see that
if torque ratings were meant to limit the squish force of the bolted together
parts, that adding the nylock portion would be the right way to get to that
force. Don't mean to drive this into the ground....
-Ben
On 11/22/2005 11:04 AM, rebaker@sc.rr.com wrote to rebel-builders:
the bolt.
-Ben
composed of the sum of the nylon insert totque and the metal nut / boltWhat Wayne is saying is that the torque you read on the torque wrench is
the resulting sum as the set value on the torque wrench for assemblyThen add that value to the torque value for the bolt from the table and use
the bolt.
nyloc nut torques
A torque rating generally is there for bolt stretch and so you don't exceed
it.....not thread stripping...although that is a great possiblity as well.
The torque required to turn the nytrol is pretty much insignificant anyhow
at less then 2 ft-lbs usually.
Sent: Tuesday, November 22, 2005 7:39 PM
Subject: RE: nyloc nut torques
forThanks Terry, Ralph. I have assumed that the torque ratings were meant
torquethe twist strain limit of the bolt itself, and that adding anything to
thus,ratings was improper. (I've twisted bolts to failure in non-aircraft hack
thatstill surprised to hear about adding torque for the nylock.) I can see
togetherif torque ratings were meant to limit the squish force of the bolted
thatparts, that adding the nylock portion would be the right way to get to
untilforce. Don't mean to drive this into the ground....
-Ben
valuethe bolt just protrudes, and by starting at zero slowly up the torque
theset on the wrench until the nut just begins to turn. That is the value
usenut alone requires to turn.Then add that value to the torque value for the bolt from the table and
the bolt.All that said, I'm going to bolt out of here before going nuts.
nyloc nut torques
I have been just using the high end of the range shown on charts. I am
always installing nuts and bolts with some sort of goop (proseal, epoxy
primer, or anti seize) and I don't believe the charts account for this. I
have to admit to the occasional extra tweak on a nut here and there as well.
Jesse
Jesse
Subject: Re: nyloc nut torques
Date: Tue, 22 Nov 2005 19:46:44 -0500
forThanks Terry, Ralph. I have assumed that the torque ratings were meanttorquethe twist strain limit of the bolt itself, and that adding anything tohackratings was improper. (I've twisted bolts to failure in non-aircraftthus,mechanic mode, but cannot recall ever breaking or stripping any nuts,thatstill surprised to hear about adding torque for the nylock.) I can seetogetherif torque ratings were meant to limit the squish force of the boltedthatparts, that adding the nylock portion would be the right way to get toisforce. Don't mean to drive this into the ground....
-Ben
What Wayne is saying is that the torque you read on the torque wrenchselfcomposed of the sum of the nylon insert totque and the metal nut / bolt
torque. The torque tables only account for the nut / bolt torque (nountillocking). Therefore, clamp a bolt lightly in your vise, run a nut onvaluethe bolt just protrudes, and by starting at zero slowly up the torquetheset on the wrench until the nut just begins to turn. That is the valueandnut alone requires to turn.Then add that value to the torque value for the bolt from the table
useseesthe resulting sum as the set value on the torque wrench for assembly
tightening. Of course, that only is valid for the first time the nutthe bolt.All that said, I'm going to bolt out of here before going nuts.
