Spring Gear - Mounting Wheel
Lonnie Benson
Post by Lonnie Benson » Fri Feb 17, 2012 5:27 pm
I am in the process of mounting my Matco wheels onto the axle on the spring gear. I placed a thin washer supplied by MAM on the axle, then the wheel, another thin washer, then the castellated nut. After tightening the nut I find that the hole for the cotter pin is about an eighth of an inch from the nut. Am I doing something wrong? Should I just add more washers to move the nut further out on the axle?
Post by Wayne G. O'Shea » Fri Feb 17, 2012 5:27 pm
Lonnie, Do you have the old gold Matco wheels or the newer alloy wheels mfg'd by Murphy?? The Matco wheels have straight roller bearings in them so only tighten the nut finger tight(actually finger loose). Stop tightening as soon as nut/washer combo touches the bearing.. If cotter won't hold nut in place, you will need to space out with washers. If you tighten the nut with a wrench, you will need 4 new bearings before you finish your taxi tests as the roller balls will chew out the bearings race edges! (don't ask me how I know!) I have over 250 hours on the old style gold wheels and I have needed to install 2 bearings since new.(other than the above mentioned 4) My gold wheels also have a 1/4" thick squash plate inside and outside to beef up the wheel hub. If you have Murphy's wheels, they have proper taper bearings in them and can be snugged up properly with a wrench(while rotating the wheel) to seat the bearing properly. Same deal with the nut on these ones also for the cotter pin. If you don't have the newer murphy wheels, I would highly suggest that before you finish the gear installation, you aquire them and install them for a trouble free future. They once had a deal to trade them in that I missed, but maybe you can swing a deal with MAM.
From: Lonnie Benson <lonben@erols.com (lonben@erols.com)>
To: Murphy Rebel Builders List <murphy-rebel@dcsol.com (murphy-rebel@dcsol.com)>
Date: Monday, November 29, 1999 10:10 AM
Subject: Spring Gear - Mounting Wheel
Lonnie Benson
Wayne: Thanks for your input. My Matco wheels are silver and have tapered bearings. When I tighten the axle nut finger tight and take all the "wobble" out of the wheel, the outer edge of the nut reaches the middle of the cotter pin hole. A couple of washers should take care of that problem. I talked with Elaine several months ago about a trade-in but my silver Matcos did not qualify. I wonder if there has been any problems with the silver Matcos other than the fact that they will not hold the airplane during run-up? It will be some time before I will be ready to fly my Rebel so I have time to ponder the question of whether or not I should switch to MAM wheels and brakes.
From: Wayne G. O'Shea <oifa@irishfield.on.ca (oifa@irishfield.on.ca)>
Date: Monday, November 29, 1999 12:50 PM
Subject: Re: Spring Gear - Mounting Wheel
Lonnie, Most brakes will not hold, because builders (and AME's) will put a new set of brakes on an aircraft and go off flying. The first high speed brake application glazes the pads! Brake pads need to be conditioned by taxing at about 1200 to 1400 rpm, and dragging the brakes with a steady pressure to maintain about 10MPH for the length of the runway. Then let cool and repeat a few times. You will be amazed at the difference. When Bob tried to test fly Howards Rebel on Amphibs, the brakes(clevelands) wouldn't hold at all and he couldn't keep the plane on the crown of our runway. Twice up and down our strip (with us holding him straight at times) was enough to get them working okay and holding. Even my old gold Matco's will hold my 150hp Lyco at full power and they have 5 1/2 years and 250 hours+ on them.
Date: Monday, November 29, 1999 5:06 PM
LisaFly99
Post by LisaFly99 » Fri Feb 17, 2012 5:27 pm
LisaFly99
THANKS for the brake breakin info thats very interesting and important.
Thanks Again P.S.&L.S.
Post by Bob Patterson » Fri Feb 17, 2012 5:27 pm
Good advice, as usual, Wayne. Don't worry, Lonnie - the reason Murphy
didn't allow an upgrade from the SILVER Matcos is that they considered them
to be acceptable for the Rebel (the GOLD Matcos were NOT sturdy enough).
If the SILVER Matcos are broken in properly, they should hold to almost
full power. Some builders would suggest that this is 'a Good Thing' (TM) :-)
as there have been a few Rebels that have been stood on the nose by the
powerful Murphy brakes !!
Yours should be just fine !
And I'm ready for Alaska anytime !!
... Although I really don't understand the fascination .... usually, by the
time we've Rambled through the Rockies, most Ramblers have had quite enough
adventure to do them for some time ! :-) I did fly a Rebel up to
Kuujuaq (old Fort Chimo), in Northern Quebec - sure is a LOT of tundra...
I guess Alaska would be much more interesting (and you wouldn't have to
fly <quite> 400+ miles between airports :-) )
------------------------------orig.--------------------------------------------
<HTML>
<HEAD>
<META content=text/html;charset=iso-8859-1
http-equiv=Content-Type><!DOCTYPE HTML PUBLIC "-//W3C//DTD W3
HTML//EN"><!DOCTYPE HTML PUBLIC "-//W3C//DTD W3 HTML//EN"><!DOCTYPE HTML
<META content='"MSHTML 4.72.3612.1706"' name=GENERATOR>
</HEAD>
<BODY bgColor=#ffffff>
<DIV><FONT color=#000000 size=2>Lonnie, Most brakes will not hold, because
need
When
wouldn't
Twice up
Lyco
at full power and they have 5 1/2 years and 250 hours+ on them.</FONT></DIV>
<DIV><FONT color=#000000 size=2></FONT>&nbsp;</DIV>
<DIV><FONT color=#000000 size=2>Wayne&nbsp;</FONT></DIV>
<BLOCKQUOTE
style="BORDER-LEFT: #000000 solid 2px; MARGIN-LEFT: 5px; PADDING-LEFT: 5px">
<DIV><FONT face=Arial size=2><B>-----Original Message-----</B><BR><B>From:
</B>Lonnie Benson <<A
href="mailto:lonben@erols.com">lonben@erols.com</A>><BR><B>To:
</B>Murphy
Rebel Builders List <<A
href="mailto:murphy-rebel@dcsol.com">murphy-rebel@dcsol.com</A>><BR><B>Date:
</B>Monday, November 29, 1999 5:06 PM<BR><B>Subject: </B>Re: Spring Gear -
Mounting Wheel<BR><BR></DIV></FONT>
<DIV><FONT color=#000000 size=2>Wayne: Thanks for your input.&nbsp; My
Matco
wheels are silver and have tapered bearings.&nbsp; When I tighten the axle
outer edge of the nut reaches the middle of the cotter pin hole.&nbsp; A
couple of washers should take care of that problem.&nbsp; I talked with
qualify.&nbsp; I wonder if there has been any problems with the silver
run-up?&nbsp; It will be some time before I will be ready to fly my
Rebel so
MAM
wheels and brakes.</FONT></DIV>
<BLOCKQUOTE
5px">
Message-----</B><BR><B>From: </B>Wayne G. O'Shea <<A
href="mailto:oifa@irishfield.on.ca">oifa@irishfield.on.ca</A>><BR><B>To:
</B>Murphy Rebel Builders List <<A
</B>Monday, November 29, 1999 12:50 PM<BR><B>Subject: </B>Re: Spring
Gear - Mounting Wheel<BR><BR></DIV></FONT>
<DIV><FONT color=#000000 size=2>Lonnie, Do you have the old gold Matco
have
will
how I
have
deal
maybe you can swing a deal with MAM.</FONT></DIV>
<DIV><FONT size=2>Wayne</FONT></DIV>
<DIV><FONT size=2></FONT>&nbsp;</DIV>
<DIV><FONT color=#000000 size=2></FONT><FONT face=Arial
size=2><B>From:
</B>Monday, November 29, 1999 10:10 AM<BR><B>Subject: </B>Spring
Gear -
<BLOCKQUOTE
PADDING-LEFT: 5px"></FONT>
<DIV><FONT color=#000000 size=2>I am in the process of mounting my
Matco wheels onto the axle on the spring gear.&nbsp; I placed a
thin
washer, then the castellated nut.&nbsp; After tightening the nut I
inch
from the nut.&nbsp; Am I doing something wrong?&nbsp; Should I
just
axle?</FONT></DIV>
size=2></FONT>&nbsp;</DIV></BLOCKQUOTE></BLOCKQUOTE></BLOCKQUOTE></BODY></HTML>
