Modified Elite Elevator
Alan Hepburn
Post by Alan Hepburn » Sat Feb 18, 2012 2:18 pm
I tried out my modifications to the Elite elevator spades this morning. The following information pertains to an elevator with spades aleady cut down to 4 1/4" wide. Also, the airplane is on amphib. floats.
Before modification of the spade leading edge, the cross section was per Murphy's design - i.e. rectangular with rounded corners. In this configuration, when pulsed downwards in cruise flight, the aircraft continues to pitch downwards - i.e. the airplane demonstrates negative dynamic stability in pitch, stick free. This pilot ran out of courage before the airplane ran out of forward pitching tendancy. Everything happens quite slowly, so is readily controllable hands on. In fact, pilots don't tend to notice the behaviour until it's pointed out to them.
The modification consists of changing the spade leading edge cross section to a semi circle. The resulting handling is certainly an improvement. The pitch stability is now just positively stable. When you pulse the stick forward and release it, the nose stays where it is for a second or so - it may even pitch a degree or so further down - then very slowly returns to the trimmed attitude. This takes about 17 seconds. I'd rather see it take something like 3 - 5 seconds. However, I'd say the change is well worth making. If anybody has any other ideas to further improve the situation, I'd like to hear them.
Al
Elite #587
Post by Wayne G. O'Shea » Sat Feb 18, 2012 2:18 pm
THANKS for the mod report Al !
Sent: Tuesday, November 08, 2005 5:51 PM
Subject: Modified Elite Elevator
Al
Elite #587
Keith B. Oliver
Post by Keith B. Oliver » Sat Feb 18, 2012 2:18 pm
Question
when you cut down the spades to 4 1/4" did you also reduce the size/weight
of the lead ??
Keith
Elite #654
Alan Hepburn
Al
Elite #587
Scott Aldrich
Post by Scott Aldrich » Sat Feb 18, 2012 2:18 pm
Al, pictures of the tips?
Scott
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Alan
Hepburn
Sent: Tuesday, November 08, 2005 3:51 PM
Al
Elite #587
Theoretically, to keep the same % of balance, you would increase the weight
as it's there to static balance the elevator and removing half the spade
takes weight away from that side of the teeter totter.
Sent: Tuesday, November 08, 2005 6:17 PM
Subject: RE: Modified Elite Elevator
Question
of the lead ??
Keith
Elite #654
Alan Hepburn
The
pilots
The
Al
Elite #587
Alan Hepburn
I'll download some pics once I get the chance to take them, but basically I
cut the ribs tips to a semi circle. This takes you back one rivet top and
bottom from the original rib flanges. I left a tab with a single rivet hole
at the leading edge, then added little 0.030" clips at the 45* points to
support the new LE skin. Then just trim and rivet in a new semi-circular
piece of 020 round the LE. Took 4 hours a side.
I may try the same trick on the rudder. It also has a tendency not to
return to neutral, but there's quite a bit more friction in the rudders due
to all those fairleads.
Another mod I'm considering is decreasing the incidence on the stab. With
floats, I'm flying around with 5* or more of up elevator all the time, which
can't be good for drag. I figure I could get away with a 1/8" shim under
the rear stab support brackets without having to rework the fiberglass
fairing. But getting at the bolts that secure the stab is a pain - pretty
well have to remove the stab. Maybe I'll take the risk and build the shims
in permanantly when I have the stab off for painting.
Al
Mike Betti
Post by Mike Betti » Sat Feb 18, 2012 2:18 pm
Al,
Nice to see you working out the bugs for my homebuilt. Also interested in
pictures.
Thanks for sharing with the group,
Mike Betti
771E
Sent: Tuesday, November 08, 2005 5:21 PM
Scott
Hepburn
The
pilots
The
Al
Elite #587
Alan Hepburn
No, same weight. The weight is not critical. Flutter is not a major
problem at 100 kts. People balance them on a knife edge, then proceed to
paint afterwards, or even add the trim servo!
cosmedi
Post by cosmedi » Sat Feb 18, 2012 2:18 pm
Al,
Apart from been a pain in the butt, could you place pictures as well as a detailed schematic diagram of meaurements of the changes. Many thanks. Also thanks for been the test pilot!!!!
Greg Elite 724
Post by Bob Patterson » Sat Feb 18, 2012 2:18 pm
Thanks for the vindication, Al !!
It's been a long time coming, but now others will be
a lot safer, because of your efforts !!!
I would hope that everyone would follow your example - including
the Moose builders... This IS a very worthwhile mod !
I believe that the rounded tip would help the rudder as well.
It's good to reduce the friction in the system as much as possible,
and it is also very important to have AT LEAST the mass balance
suggested by the factory (75%). As someone who has suffered
elevator flutter, right down to stall speed - it CAN happen at
ANY speed, and mass balance, and rigidity of the tip horns
IS very important !!
We added a wide strip of .032 most of the way around the
inside of the elevator & rudder tips on the Rebel. The original
fiberglass was thin and 'wiggly' - the extra stiffness, and
extra weight, helped a lot to prevent oscillation & twisting.
The beefups to the end ribs also help, and may have been partly
necessary because of the original flexiness ...
Al
Elite #587
Mike Betti
Post by Mike Betti » Sat Feb 18, 2012 2:33 pm
Al,
During your elevator mod, were the weights in the way or have to be trimmed?
Mike Betti
771E
Sent: Tuesday, November 08, 2005 7:13 PM
Subject: Re: Modified Elite Elevator
hole
due
which
shims
Al
Alan Hepburn
Post by Alan Hepburn » Sat Feb 18, 2012 2:33 pm
Mike:
I take it you're talking the semi-circular tips. If so, the answer is "No".
I'd forgotten what shape the weights were, but when I cut it open I was
pleased to discover that they taper from about 1 1/2" to maybe 3/4" at the
tip. So no interference.
Al
Mike Betti
Ok thanks Al,
How about some pictures of your mod? I think I know what you did, but a
picture would help.
Sent: Friday, December 16, 2005 8:27 PM
Mike:
"No".
Al
Post by Mike Davis » Sat Feb 18, 2012 2:33 pm
There are photos in the E-Modifications file area Mike.
Sent: Friday, December 16, 2005 6:18 PM
Ok thanks Al,
picture would help.
Mike:
"No".
Al
Mike Betti
Thanks Mike,
I been looking in the E-elevator.
Sent: Friday, December 16, 2005 9:39 PM
Ok thanks Al,
picture would help.
Mike:
"No".
Al
