Interesting, another MT Beta problem. The MT guys in Germany had a
conniption fit when they saw our postings about Les's MT in Alaska going
into reverse. They actually sent a nasty gram off list to a member. Screw
them - whether it is actually going into "reverse" or just going flat as
they claim, you're still just as dead either way.
Scott
bscheube@dcsol.com
Sent: Tuesday, November 01, 2005 11:11 PM
Subject: Larry Nagy completed Moose
Guys,
Just thought I would pass this e-mail along that I received from Larry a
while ago. I has to do govenor. I am glad he wasn't in the air!! read
below.......He has his Moose for sale if there is any interest you can
contact
Larry at ljnagy@axion.net
Bob....Was glad to hear that you have started building.... the new , pre
punched kits certainly do cut a few hours off the building time....You did
the right thing buying that engine, they will not get any cheaper . I should
mention that on mine, I installed the composite , 3-blade ,MT prop, with
which I am very pleased. I also had a new prop govenor with reverse pitch
control. During run up, it locked into coarse pitch and refused to respond.
It was defective from the factory and luckily , I still had the original
,new
standard govenor that came with the engine. That is the one I'm flying with
now and it works very well...don't know if you seen that artical on the
Moose
that crash landed in the parking lot in Anchorage last fall, but apparently,
his prop went into coarse pitch on final and I too would like to know
why !! I love my Moose but there comes a time when it's time to get out of
the lodge business and do something else..I have the tail feather kit for an
RV-7 in my workshop so if the Moose sells, I will probably start on it or
maybe an RV-10 ??? Larry
Another MT prop issue was RE: Larry Nagy completed Moose
Don't know much about the MT prop but with my NSI CAP beta prop there are
spring pins that engage over 2000RPM (engine speed about 1000 prop RPM) that
prevent it going finer than takeoff pitch. One thing I have found out with my
prop is that the control buttons on the stick are very sensitive and even you
or the co-pilot rest a map on the buttons it can change the pitch unexpectly.
I would caution anyone with a cap prop to be thoroughly aware of how it works
and any idiosyncrasies. Going into flat pitch while flying for any reason is
not acceptable and in my opinion is a design flaw.
Ray
it will locOn 11/2/2005 7:33 AM, sa@mwutah.com wrote to rebel-builders:
-> Interesting, another MT Beta problem. The MT guys in Germany had a
-> conniption fit when they saw our postings about Les's MT in Alaska going
-> into reverse. They actually sent a nasty gram off list to a member. Screw
-> them - whether it is actually going into "reverse" or just going flat as
-> they claim, you're still just as dead either way.
-> Scott
-> -----Original Message-----
-> bscheube@dcsol.com
-> Sent: Tuesday, November 01, 2005 11:11 PM
-> Subject: Larry Nagy completed Moose
-> Guys,
-> Just thought I would pass this e-mail along that I received from Larry a
-> while ago. I has to do govenor. I am glad he wasn't in the air!! read
-> below.......He has his Moose for sale if there is any interest you can
-> contact
-> Larry at ljnagy@axion.net
-> Bob....Was glad to hear that you have started building.... the new , pre
-> punched kits certainly do cut a few hours off the building time....You did
-> the right thing buying that engine, they will not get any cheaper . I
should
-> mention that on mine, I installed the composite , 3-blade ,MT prop, with
-> which I am very pleased. I also had a new prop govenor with reverse pitch
-> control. During run up, it locked into coarse pitch and refused to
respond.
-> It was defective from the factory and luckily , I still had the original
-> ,new
-> standard govenor that came with the engine. That is the one I'm flying
with
-> now and it works very well...don't know if you seen that artical on the
-> Moose
-> that crash landed in the parking lot in Anchorage last fall, but
apparently,
-> his prop went into coarse pitch on final and I too would like to know
-> why !! I love my Moose but there comes a time when it's time to get out
-> the lodge business and do something else..I have the tail feather kit for
an
-> RV-7 in my workshop so if the Moose sells, I will probably start on it or
-> maybe an RV-10 ??? Larry
-> List archives located at: https://www.dcsol.com/login
-> Subscription services located at:
-> https://www.dcsol.com/public/code/html-subscribe.htm
Ray
-> Scott
-> Guys,
-> contact
should
respond.
-> ,new
with
-> Moose
apparently,
an
I don't know anything about the MT prop specifically although I do have
thousands of hours on reversable turboprops, but it sounds like you guys are
talking about two separate problems. Larry describes his prop locking in
coarse pitch, which refers to high blade angle ie feather. That would not
drop you out of the sky like what happened to Les. That does sound like a
case of uncommanded beta.
Jesse
Jesse
Subject: Another MT prop issue was RE: Larry Nagy completed Moose
Date: Wed, 2 Nov 2005 09:33:05 -0700
Scott
bscheube@dcsol.com
Guys,
contact
should
,new
Moose
apparently,
an
