Rebel Rudder
Brian Breathnach
Rebel Rudder
Post by Brian Breathnach » Sat Feb 18, 2012 2:06 pm
So, I very very carefully read through the section of the manual on the Rebel tail feathers as that is where the build was to start.
Then, I very very carefully measured and drilled the rudder parts as per the manual and took great care to get the parts all lined up and fitting right.
So far so good
Next came the rudder assembly as per the manual. Thus, the rudder horn was neatly and properly riveted to the spar cap in a way that would make the workmanship of those who built the steel riveted side plates of the Titanic look like the work of infants building a Meccano set--you know where this is going right?
Again all went well.
Next came my attempt to rivet the horn and spar cap assembly to the rudder spar.
Thats when I discovered that a couple of the rivets used to attach the the cap to the spar could not be inserted in place, and pulled, because of interference from a couple of rivets used to attach the horn to the cap and about which the manual offered no caution; indeed it was as silent as a tomb on the subject.
Thats when I nearly had a ##!!0&%##@/!!!!!! bird
Has this happened to anyone else? if it has I would sure appreciate any fix that was dreamed up. But somehow I just know in my bones that it's into the hip pocket and out with the wallet to buy a new spar and cap to redo the whole 30 hour effort.
Right?
I thought so!
Sympathy, and expressions of shock grief and horror, may be sent to the undersigned.
Brian Breathnach
779R
Jones, Michael
Rebel Rudder
Post by Jones, Michael » Sat Feb 18, 2012 2:06 pm
brian
can you remove the rivets that are in the way and put back after the others
are installed, or
sometimes if you pull the rivet slowly with low air pressure and push really
hard on the rivet gun you can get the offending rivet in place the give it
one last hard pull with more air pressure to finish it off
mike#007
Brian Breathnach
Sent: Monday, October 31, 2005 2:09 AM
Subject: Rebel Rudder
So far so good
going right?
spar.
on the subject.
Right?
I thought so!
undersigned.
Brian Breathnach
779R
rebel rudder
Post by Ralph Baker » Sat Feb 18, 2012 2:06 pm
What I have done when absolutely backed into a corner on this issue is to carefully knock out the mandrel in a new rivet, shorten the rivet slightly, reinsert the mandrel and pul the shortened rivet. The caution of course, is that there must be adequate rivet barrel to head up properly and only minimal shortening is possible.
Another help would be to knock out the offending (set) rivet mandrel and gain a small amount of reach for the new rivet. If you were concerned about shear a section of mandrel could be reinserted with epoxy to fix it. I believe Darryl does not count on the mandrel when designing.
I don't really like to do either of the above but this does occur ocassionally and my sense is that disassembly creates more risk of strength compromise than the above. I would however consider carefully in high stress locations. As always, the risk of the decision is yours.
Jesse Jenks
Rebel Rudder
Post by Jesse Jenks » Sat Feb 18, 2012 2:06 pm
Brian,
I ran into the same problem, and was equally as pi$$ed off about the manual.
It is the first bit of education you receive that the manual is a piece of
junk. You will learn that pretty quick.
I hadn't pulled any rivets before I realized the interference problem. What
I did was to counter bore slightly the inside of the holes for the 2
offending rivets that go through horn and end plug, and used the shorter SS
rivets in those 2 locations. When pulled, the shop head is almost flush to
the inner surface of the plug and the opposing rivets from the side will
clear them. As I remember, this problem is caused by the the hole location
of the two side rivets that are located by the rudder (or elevator) skin.
With the remaining radialy spaced rivets you can locate them far enough away
from the end of the plug that there is no clearance problem. On the rest of
the control surfaces I changed those hole locations slightly. If you counter
bore the inside of those 2 holes, use a drill press and secure the end plug
well. The drill bit will grab and want to go all the way through. If you
have an actual counter bore bit, even better.
Jesse
Date: Sun, 30 Oct 2005 23:08:55 -0800
right.
So far so good
spar.
Right?
I thought so!
undersigned.
Brian Breathnach
779R
mbetti
rebel rudder
Post by mbetti » Sat Feb 18, 2012 2:06 pm
I was told by MAM that the airplane is designed with 10% extra rivets. So I would think it's alright to rig one once in the while like Ralph mentions.
Mike Betti
771E
Rebel Rudder
Post by Mike Davis » Sat Feb 18, 2012 2:06 pm
I know it's not exactly pretty, but it's not that visible on the bottom of
the rudder... drill out the offending rivets and install them backwards,
from the inside out.
195SR
Sent: Sunday, October 30, 2005 10:08 PM
right.
So far so good
spar.
Right?
I thought so!
undersigned.
Brian Breathnach
779R
Rebel Rudder
Post by Wayne G. O'Shea » Sat Feb 18, 2012 2:06 pm
Not an option Mike. Needs to be smooth as it rotates above the hinge
bracket. In backwards would leave the "shop" heads working like a baseball
card in your spokes!
Sent: Tuesday, November 01, 2005 5:15 PM
Subject: Re: Rebel Rudder
195SR
right.
So far so good
was
rudder
spar.
as
Right?
I thought so!
undersigned.
Brian Breathnach
779R
Rebel Rudder
OK, I was picturing it like the Moose rudder horn... wouldn't interfere with
the hinging on a Moose.
Sent: Tuesday, November 01, 2005 1:28 PM
195SR
per
fitting
right.
So far so good
was
rudder
spar.
as
Right?
I thought so!
undersigned.
Brian Breathnach
779R
__________ NOD32 1.1270 (20051101) Information __________
This message was checked by NOD32 antivirus system.
http://www.eset.com
Rebel Rudder
Rebel rudder horn goes right on the bottom similar to the Moose tailwheel
steering arm. This sits right on top of the rudder pivot. Only clearance
available is for one of my nylon pog to keep even the smooth rivet heads
from wearing into the pivot bracket.
Sent: Tuesday, November 01, 2005 9:21 PM
with
baseball
backwards,
195SR
horn
was
know
rudder
cap
silent
as
any
it's
http://www.eset.com
Brian Breathnach
Rebel Rudder
Hi Mike,
Thank you for the prompt response.
Have established that the absence of a mandril in a rivet does not affect
the safety of the kit so the intent is to remove the mandril and that will
allow me to insert and pull the appropriate rivets. Being new to the build
experience I was/am intrigued by the low air pressure and hard push
technique you describe below. Will keep that in mind for sure.
thanx again Mike
Brian
From: "Jones, Michael" <Michael.Jones@snclavalin.com>
Sent: Tuesday, November 01, 2005 4:31 AM
Subject: RE: Rebel Rudder
brian
others
are installed, or
really
mike#007
Brian Breathnach
right.
So far so good
was
Titanic
is
going right?
spar.
tomb
on the subject.
fix
Right?
I thought so!
undersigned.
Brian Breathnach
779R
Rebel Rudder
Most of the mandrels "ping" right out of the stainless rivets when the
mandrel breaks anyhow.
Another trick is the old plastic mallet on the air riveter head as you
slowly pull the rivet...to drive the rivet into place as the shop head
forms.
Sent: Monday, October 31, 2005 11:29 PM
Hi Mike,
thanx again Mike
Brian
brian
others
are installed, or
really
it
mike#007
Brian Breathnach
right.
So far so good
was
Titanic
this
is
going right?
rudder
spar.
tomb
on the subject.
fix
Right?
I thought so!
undersigned.
Brian Breathnach
779R
Brian Breathnach
rebel rudder
Hi Ralph,
Your prompt response is much appreciated.
Have confirmed your thought on the absence of a rivet mandrel (para two
below) and I will likely go that way.
Thank you for the feedback
Brian
Sent: Tuesday, November 01, 2005 5:27 AM
Subject: rebel rudder
Brian Breathnach
Rebel Rudder
Hi Jesse,
Thanks for the feedback.
Im new to this building game so that will explain my curiosity about a
"counter bore." If you wouldnt mind Jesse could you provide a little more
explanation on the concept as a means of keeping me out of trouble when
building the elevators/fin.
Many thanks
Brian
Sent: Tuesday, November 01, 2005 9:33 AM
Brian,
manual.
What
SS
away
counter
plug
Jesse
right.
So far so good
rudder
spar.
fix
Right?
I thought so!
undersigned.
Brian Breathnach
779R
Brian Breathnach
rebel rudder
Thanks Mike--looks like that will be the route I will go
Brian
Sent: Tuesday, November 01, 2005 10:54 AM
Subject: Re: rebel rudder
Mike Betti
771E
Brian Breathnach
Rebel Rudder
Post by Brian Breathnach » Sat Feb 18, 2012 2:07 pm
Hi Wayne,
Thanx for the info.
Im new to building so that explains this question. Does "ping" mean that the
mandrel removes itself from the rivet leaving a hole right tru the body of
the rivet? Also if you could elaborate on the use of the "plastic mallet on
the air riveter head..." that would be great. Is the idea to actually whack
the riveter head during the process of pulling the rivet?
Thank you
Brian
Sent: Tuesday, November 01, 2005 8:39 PM
forms.
Hi Mike,
affect
will
build
thanx again Mike
Brian
brian
others
are installed, or
really
give
it
mike#007
Brian Breathnach
per
right.
So far so good
horn
was
Titanic
this
is
going right?
rudder
spar.
cap
tomb
on the subject.
any
fix
into
Right?
I thought so!
undersigned.
Brian Breathnach
779R
