pro seal party..
Jean Poirier
pro seal party..
Post by Jean Poirier » Sat Feb 18, 2012 2:06 pm
Hello everybody!
Yesterday I have separate 2 parts (top tank skin and filler neck) that were riveted and proseal-ed......
Than I remembered that Darryl suggest me (couple of years ago at a Sun'fun) that I could use proseal between the corner wrap and the fuselage side to prevent water inside the fuselage. But if I have a repair to do........ Someone know if I could use the same silka as people often use for float? As it is just for water sealing... it should be ok?
Jean
Rebel 747R
pro seal party..
Post by Bob Patterson » Sat Feb 18, 2012 2:06 pm
Hi Jean !
Sika-Flex would work ..... and so does the standard
PolyFiber Epoxy Primer ! :-)
On Wednesday 26 October 2005 02:31 pm, Jean Poirier wrote:
Hello everybody!
Jean
Rebel 747R
