As you know about 15 rebels on the island.Most have full lotus.I hate the look.Only two sets off murphy floats.Both owners say rebel is under floated with the 1800.I can get a new set off wipair clones professionally built ready to bolt on for $19,000.00.
Regards: alvin
wipair 2100
wipair 2100
"Both owners say rebel is under floated with the 1800"
Yes it is when loaded to over 2000 lbs!!!! ))
Mine sits nice and high in the water at just shy of 1800lbs. I can't see
even another 200 making it undesirable...especially when we're really
supposed to be topping out at 1730lbs gross.
From: "Alvin and Glenys Adams" <gander.electrical@nf.sympatico.ca>
To: "rebel" <rebel-builders-d@dcsol.com>
Sent: Saturday, October 15, 2005 6:53 PM
Subject: wipair 2100
look.Only two sets off murphy floats.Both owners say rebel is under floatedAs you know about 15 rebels on the island.Most have full lotus.I hate the
Regards: alvin
Wipair 2100
Gooday wayne:
Yhe last rebel down here was registersd for 2000 lbs gross weight.Test were done with the aircraft at 2000 lbs.It is on 2150 full lotus.I assume i will be able to register mine at 2000 lbs so i guess i need floats for 2000 lbs.
Maby i am off track.
Welcome your input.
alvin
Welcome your input.
alvin
Wipair 2100
Mine is bumped to that weight as well Alvin...and if my aircraft wasn't
paperwork legal at these weights I wouldn't be typing those weights on a
public forum..TFSure. In the certified world....1800 floats are legal at
2000lbs GW..but not a lb more. Mind you in the homebuilt world you don't
have to follow the bouyancy rule...smart if you do...but not a legal
requirement in CARS.
I understand the Easterners are happy on the Lotus floats due to landscape
and salt water issues...even though I am told they are like flying on sand
paper. Maybe you have enough inside information from your local friends to
dispell that rumour. I've never flown on them.
Sent: Saturday, October 15, 2005 8:41 PM
Subject: Wipair 2100
lbs.
were done with the aircraft at 2000 lbs.It is on 2150 full lotus.I assume iGooday wayne:
lbs.
Welcome your input.
alvin
