2100 wipair Straight floats
Gooday Folks;
Trying to decide what float to purchase for rebel with 160 HP.Can buy a
set off 2100 wipair clones.Whould they be a good match.Has anyone every
installed same on rebel.Without a another rebel to get measurements from
i guess it would be very difficult to do the first setup.
Regards: Alvin 776
About 40% complete I hope.
Regards: Alvin 776
Take a look at the Montana 2200s (www.montanafloat.com). Available as kit
or ready built. But if you're going for amphibs, watch the weight.
Al
Al
Guess you're talking a set of Eddie floats! Shouldn't be that difficult to
mount. Find the c o g of the floats by rolling a metal tube under the float
step keels. Line the float c of g up with the empty aircraft c of g and
start making struts. What we are finding for an ultimate throat angle on the
Rebels is between 2.7 and 3.5 degrees. This is float top level, cabin bottom
2.7 to 3.5 nose up. Mine is at 3.0 degrees and lands/take offs ever so
nicely with a mere 8 second run into a breeze at 1700lbs! with 150 HP.
When you get there Alvin I am sure many will be willing to take measurements
and send you pictures so your installation is a success.
From: "Alvin and Glenys Adams" <gander.electrical@nf.sympatico.ca>
To: "rebel" <rebel-builders-d@dcsol.com>
Sent: Sunday, October 09, 2005 1:58 PM
Subject: 2100 wipair Straight floats
Gooday Folks;
Regards: Alvin 776
Hmmm, 8 seconds, that's pretty good, Wayne, and assume you still
have that puny tooth pick Warp Drive prop, too. I think I may
have to change mine to 3 degrees as well. I plan to take my
floats off some time this winter for a full maintenance check,
and might even paint them before reinstalling.
Sent: Sunday, October 09, 2005 3:18 PM
Subject: Re: 2100 wipair Straight floats
aircraft c of g and
with 160 HP.Can buy aGooday Folks;
Trying to decide what float to purchase for rebelmatch.Has anyone everyset off 2100 wipair clones.Whould they be a goodget measurements frominstalled same on rebel.Without a another rebel to-------------------------------------------------------i guess it would be very difficult to do the first setup.
Regards: Alvin 776
-----------------------------------------------------------------List archives located at: https://www.dcsol.com/login
Counting "thousand and one...thousand and two...etc". so maybe a second or
two longer...but no more. Off the grass in no wind @1790lbs takes about 500
to 600 feet max....so pavement in the 450 to 500 foot category.
Paint = Weight ! and a harder to clean scum line.
If you have a set of holes left on the back struts, or two, drop it down and
see what it does. I found it made VERY little difference on the
X-cable/turnbuckles length when I did Howard's so you shouldn't need to make
anything new.
Sent: Sunday, October 09, 2005 8:59 PM
Subject: RE: 2100 wipair Straight floats
anything new.
aircraft c of g and
Regards: Alvin 776
...and remember we're talking 750' ASL on my grass field and 962'ASL on my
lake...not what you're into where you go!
Sent: Sunday, October 09, 2005 9:10 PM
500Counting "thousand and one...thousand and two...etc". so maybe a second or
andto 600 feet max....so pavement in the 450 to 500 foot category.
makesee what it does. I found it made VERY little difference on the
anything new.
aircraft c of g and
with 160 HP.Can buy a match.Has anyone every get measurements from -------------------------------------------------------
I've got some solid salt water lines on the floats now, so assume
paint would prevent that. Besides, I need to pretty it up a bit,
if I'm coming out see you guys next summer. I've got some
hydraulic leaks coming from the back gear somewhere, so will have
to check that out real good. Can't tell where its coming from
with the floats on, but it is making a mess of my paved hangar
floor. And maybe I'll try seal off those grommets on my front
gear wells. Getting tired of having to pump out my 3rd from the
front compartments every time I'm in rough water.
Harrison Lake is only 40 ft ASL. But yes, high alpine lakes are a
whole different story.
Sent: Sunday, October 09, 2005 6:14 PM
two...etc". so maybe a second orCounting "thousand and one...thousand and@1790lbs takes abouttwo longer...but no more. Off the grass in no wind
500foot category.to 600 feet max....so pavement in the 450 to 500or two, drop it downPaint = Weight ! and a harder to clean scum line.
anddifference on thesee what it does. I found it made VERY littleyou shouldn't need toX-cable/turnbuckles length when I did Howard's so
makeassume you stillanything new.
Hmmm, 8 seconds, that's pretty good, Wayne, andthink I mayhave that puny tooth pick Warp Drive prop, too. Imaintenance check,have to change mine to 3 degrees as well. I plan to take my
floats off some time this winter for a fullfirst setup.and might even paint them before reinstalling.
Howard uses a boat anti-fowling wax at the water line that seems to work
well on the bare alum.
Sent: Sunday, October 09, 2005 9:28 PM
think I maymaintenance check,first setup.-------------------------------------------------------
