Rebel Bulkhead Pressing
G'day Everyone !
I have a quick question I need to clarify - before I get some parts
from MAM
(because I don't think the person I am talking to understands what I
have asked for)
Background:
I need to get a few of the "R Bulk 1" bulkhead pressings ....
These are the Square edged pressings - used at the bottom edge of the
fuselage - right under where the seats are located.
They are also where the rear, bungee gear attach point is.
(the pressing is square on the outer edged lip & curved on the inner
edge lip)
In my parts list that I have just requested .... I asked for 6 of these
corners
Now - from memory, this bulkhead comes as a single pressing that has 2
corners on it
ie: it makes up a complete bulkhead on the bottom of the fuse - from one
side to the other
On the plan - this is shown as "Bulkhead A"
There are a total of 3 of these pressings used in a Rebel
Two of them are back to back - spaced 1" apart , with a short square
tube between them - this is where ther rear bungee gear leg attaches
The other bulkhead makes up the next, forward bulkhead - just about in
line with the front edge of the seats
The question is :
Does this "R Bulk 1" pressing have 2 edges / corners on it, or 1 ???
I have assumed that this pressing has 2 corners - and asked if the
pressing can be cut in half (for compact shipping) - and stacked one on
top of each other - to save space ... thereby making a STACK of 6
corners
The trouble is - I think MAM is quoting me for 6 PRESSINGS - which will
be 12 corners in all - and at a cost of over $300 !
Can someone please verify what this pressing looks like - it is 7 AM
here & I'd like to ring & clarify this all with MAM - before they shut
down for the day (it should be about 2 PM in Canad by my calc's)
Many Thanks All
Rick Harper
541R
from MAM
have asked for)
Background:
edge lip)
corners
corners on it
side to the other
The question is :
corners
Many Thanks All
Rick Harper
541R
PS --- I should have also said
If the bulkhead pressing has 2 corners on it - it would look like a
square edged "U"
If it is a single edge / corner - it would look like an elbow / 90
degree bend only
Rick
541R
Sent: Thursday, September 22, 2005 7:00 AM
Subject: Re: Rebel Bulkhead Pressing
G'day Everyone !
parts from MAM
have asked for)
Background:
edge lip)
these corners
2 corners on it
one side to the other
The question is :
corners
will be 12 corners in all - and at a cost of over $300 !
Many Thanks All
Rick Harper
541R
square edged "U"
degree bend only
Rick
541R
G'day Everyone !
parts from MAM
have asked for)
Background:
edge lip)
these corners
2 corners on it
The question is :
corners
Many Thanks All
Rick Harper
541R
Rick...they are only one corner...ie you have to join two of them together
to make the U...just like all the bulkheads in the tailcone.
Therefore if you need to make 3 full U's...you need to order 6 of the
bulheads...and make sure you tell them not to cut them in half LOL.
To: "Rick Harper" <rjwh@optusnet.com.au>; <rebel-builders@dcsol.com>
Sent: Wednesday, September 21, 2005 5:09 PM
square edged "U"
degree bend only
Rick
541R
G'day Everyone !
parts from MAM
have asked for)
Background:
edge lip)
these corners
2 corners on it
The question is :
corners
Many Thanks All
Rick Harper
541R
Oh and by the way...I think they are only sending you 6...as they are just
shy of $55cdn each generally!
Sent: Wednesday, September 21, 2005 6:19 PM
square edged "U"
degree bend only
Rick
541R
G'day Everyone !
parts from MAM
have asked for)
Background:
edge lip)
these corners
2 corners on it
The question is :
corners
Many Thanks All
Rick Harper
541R
Thanks Wayne !
Just spoke to Nancy at MAM & paid for the order ....
I goofed on the square bulkhead pressing :o(
I'm going to "stitch" each square corner in with overlapping .040"
sheet ..... way too hard to replace the whole bulkhead ! (especially
since it's only the corners that are damaged )
Thanks for your help !
Rick
Sent: Thursday, September 22, 2005 8:19 AM
together
Rick
together
square edged "U"
degree bend only
Rick
541R
G'day Everyone !
parts from MAM
thehave asked for)
Background:
innerfuselage - right under where the seats are located.
hasedge lip)
these corners
from2 corners on it
squareone side to the other
about intube between them - this is where ther rear bungee gear leg attaches
???line with the front edge of the seats
The question is :
onI have assumed that this pressing has 2 corners - and asked if the
AMtop of each other - to save space ... thereby making a STACK of 6
corners
shuthere & I'd like to ring & clarify this all with MAM - before they
Many Thanks All
Rick Harper
541R
Been there done that Rick....can even dig up and send you some pics to boot!
Sent: Wednesday, September 21, 2005 6:29 PM
Thanks Wayne !
Rick
together
square edged "U"
degree bend only
Rick
541R
G'day Everyone !
parts from MAM
(because I don't think the person I am talking to understands whatthehave asked for)
Background:
These are the Square edged pressings - used at the bottom edge ofinnerfuselage - right under where the seats are located.
(the pressing is square on the outer edged lip & curved on thehasedge lip)
these corners
Now - from memory, this bulkhead comes as a single pressing thatfrom2 corners on it
ie: it makes up a complete bulkhead on the bottom of the fuse -squareone side to the other
Two of them are back to back - spaced 1" apart , with a shortabout intube between them - this is where ther rear bungee gear leg attaches
The other bulkhead makes up the next, forward bulkhead - just???line with the front edge of the seats
The question is :
Does this "R Bulk 1" pressing have 2 edges / corners on it, or 1onI have assumed that this pressing has 2 corners - and asked if the
pressing can be cut in half (for compact shipping) - and stacked oneAMtop of each other - to save space ... thereby making a STACK of 6
corners
Can someone please verify what this pressing looks like - it is 7shuthere & I'd like to ring & clarify this all with MAM - before theydown for the day (it should be about 2 PM in Canad by my calc's)
Many Thanks All
Rick Harper
541R
Yes please !
Rick
Sent: Thursday, September 22, 2005 8:35 AM
boot!
Rick
boot!
Thanks Wayne !
thesince it's only the corners that are damaged )
Rick
together
LOL.bulheads...and make sure you tell them not to cut them in half
<rebel-builders@dcsol.com>Wayne
like aSent: Wednesday, September 21, 2005 5:09 PM
90square edged "U"
somedegree bend only
Rick
541R
G'day Everyone !
whatparts from MAM
ofIhave asked for)
Background:
thethefuselage - right under where the seats are located.
6 ofinneredge lip)
thatthese corners
-has2 corners on it
attachesfromsquareone side to the other
Two of them are back to back - spaced 1" apart , with a shorttube between them - this is where ther rear bungee gear leg
or 1about inThe other bulkhead makes up the next, forward bulkhead - justline with the front edge of the seats
The question is :
the???I have assumed that this pressing has 2 corners - and asked if
onepressing can be cut in half (for compact shipping) - and stacked
6ontop of each other - to save space ... thereby making a STACK of
whichcorners
is 7will be 12 corners in all - and at a cost of over $300 !
theyAMhere & I'd like to ring & clarify this all with MAM - before
-----------------------------------------------------------------shutdown for the day (it should be about 2 PM in Canad by my calc's)
Many Thanks All
Rick Harper
541R
-----------------------------------------------------------------List archives located at: https://www.dcsol.com/login
Oops ... my e-mail is rjwh@optusnet.com.au ....
Thanks !
Rick
boot!
Thanks !
Rick
boot!
Thanks Wayne !
Rick
together
90square edged "U"
Rick
541R
G'day Everyone !
whatparts from MAM
ofIhave asked for)
Background:
6 ofinneredge lip)
thatthese corners
-has2 corners on it
The question is :
whichcorners
Many Thanks All
Rick Harper
541R
Yep got it...have to eat and then will locate, downsize and send you some
footage!
Sent: Wednesday, September 21, 2005 6:36 PM
footage!
Thanks !
Rick
boot!
Thanks Wayne !
sheet ..... way too hard to replace the whole bulkhead ! (especiallythesince it's only the corners that are damaged )
Rick
together
Therefore if you need to make 3 full U's...you need to order 6 ofLOL.bulheads...and make sure you tell them not to cut them in half<rebel-builders@dcsol.com>Wayne
To: "Rick Harper" <rjwh@optusnet.com.au>;like aSent: Wednesday, September 21, 2005 5:09 PM
If the bulkhead pressing has 2 corners on it - it would look90square edged "U"
If it is a single edge / corner - it would look like an elbow /somedegree bend only
Rick
541R
G'day Everyone !
I have a quick question I need to clarify - before I getwhatparts from MAM
(because I don't think the person I am talking to understandsofIhave asked for)
Background:
These are the Square edged pressings - used at the bottom edgethethefuselage - right under where the seats are located.
(the pressing is square on the outer edged lip & curved on6 ofinneredge lip)
In my parts list that I have just requested .... I asked forthatthese corners
Now - from memory, this bulkhead comes as a single pressing-has2 corners on it
ie: it makes up a complete bulkhead on the bottom of the fuseattachesfromsquareone side to the other
Two of them are back to back - spaced 1" apart , with a shorttube between them - this is where ther rear bungee gear legor 1about inThe other bulkhead makes up the next, forward bulkhead - justline with the front edge of the seats
The question is :
Does this "R Bulk 1" pressing have 2 edges / corners on it,the???I have assumed that this pressing has 2 corners - and asked ifonepressing can be cut in half (for compact shipping) - and stacked6ontop of each other - to save space ... thereby making a STACK ofwhichcorners
The trouble is - I think MAM is quoting me for 6 PRESSINGS -is 7will be 12 corners in all - and at a cost of over $300 !
Can someone please verify what this pressing looks like - ittheyAMhere & I'd like to ring & clarify this all with MAM - before-----------------------------------------------------------------shutdown for the day (it should be about 2 PM in Canad by my calc's)
Many Thanks All
Rick Harper
541R
Bewdy !
I'm off to work on my hangar ... I'll check it out tonight
Rick
Sent: Thursday, September 22, 2005 8:43 AM
some
footage!
Rick
some
footage!
pics toOops ... my e-mail is rjwh@optusnet.com.au ....
Thanks !
Rick
.040"boot!
Thanks Wayne !
(especiallysheet ..... way too hard to replace the whole bulkhead !
themsince it's only the corners that are damaged )
Rick
oftogether
elbow /theLOL.bulheads...and make sure you tell them not to cut them in half<rebel-builders@dcsol.com>Wayne
If the bulkhead pressing has 2 corners on it - it would looksquare edged "U"
get90degree bend only
Rick
541R
G'day Everyone !
understandssomeparts from MAM
....whatIhave asked for)
Background:
edgeThese are the Square edged pressings - used at the bottom
onofthefuselage - right under where the seats are located.
fortheinneredge lip)
pressing6 ofthese corners
fusethathas2 corners on it
short-fromone side to the other
justattachessquaretube between them - this is where ther rear bungee gear legThe other bulkhead makes up the next, forward bulkhead -
it,about inline with the front edge of the seats
The question is :
asked ifor 1???I have assumed that this pressing has 2 corners - and
stackedthepressing can be cut in half (for compact shipping) - and
ofoneontop of each other - to save space ... thereby making a STACK
-6corners
itwhichwill be 12 corners in all - and at a cost of over $300 !
calc's)is 7theyAMhere & I'd like to ring & clarify this all with MAM - beforeshutdown for the day (it should be about 2 PM in Canad by my
----------------------------------------------------------------------------------------------------------------------------------Many Thanks All
Rick Harper
541R
Hi Wayne,
Would you be able to post those pics to the website too? Thanks.
Fred
Sent: Wednesday, September 21, 2005 6:43 PM
some footage!
password "builder"
Fred
some footage!
.040"Oops ... my e-mail is rjwh@optusnet.com.au ....
Thanks !
Rick
to boot!
Thanks Wayne !
them(especiallysheet ..... way too hard to replace the whole bulkhead !
Rick
oftogether
understands90somedegree bend only
Rick
541R
G'day Everyone !
I have a quick question I need to clarify - before I getparts from MAM
Background:
forofthethefuselage - right under where the seats are located.
(the pressing is square on the outer edged lip & curved oninneredge lip)
fuse6 ofthatthese corners
Now - from memory, this bulkhead comes as a single pressinghas2 corners on it
ifor 1about inline with the front edge of the seats
The question is :
Does this "R Bulk 1" pressing have 2 edges / corners on it,???I have assumed that this pressing has 2 corners - and asked
calc's)6whichcorners
Can someone please verify what this pressing looks like - ittheyAMhere & I'd like to ring & clarify this all with MAM - beforeshutdown for the day (it should be about 2 PM in Canad by my
Rick Harper
541R
password "builder"
Have you damaged your Rebel and require these?
They're no good for a first time build...just how to fish a damaged set of
drag brace bulkheads out.
Sent: Thursday, September 22, 2005 9:47 AM
Subject: RE: Rebel Bulkhead Pressing
Hi Wayne,
Fred
some footage!
Thanks !
Rick
to boot!
Thanks Wayne !
I'm going to "stitch" each square corner in with overlappingthem(especiallysheet ..... way too hard to replace the whole bulkhead !
Rick
Rick...they are only one corner...ie you have to join two ofoftogether
Therefore if you need to make 3 full U's...you need to order 6/theLOL.bulheads...and make sure you tell them not to cut them in half<rebel-builders@dcsol.com>Wayne
understands90some....whatIedgeforofthetheinnerfuse6 ofthathasshort-fromjustattachessquareifor 1about in???stackedtheofoneoncalc's)6whichis 7theyAMshut--------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------List archives located at: https://www.dcsol.com/login
password "builder"
Nope, guess not. I was just trying to learn all I could, when I could.
Sent: Thursday, September 22, 2005 9:13 PM
of drag brace bulkheads out.
password "builder"
elbowHi Wayne,
Fred
some footage!
Thanks !
Rick
pics to boot!
Thanks Wayne !
Rick
Therefore if you need to make 3 full U's...you need to order 6theLOL.bulheads...and make sure you tell them not to cut them in half<rebel-builders@dcsol.com>Wayne
get/90
onunderstandssome....whatIedgeofthe
pressingfortheinner6 of
it,fusethathasshort-fromjustattachessquareabout in
askedor 1???
-ifstackedtheofoneon6
itwhich
-----------------------------------------------------------------calc's)is 7theyAMshut--------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------List archives located at: https://www.dcsol.com/login
"rebel"
password "builder"
password "builder"
