Got to thinking while I was tearing away on Daryl's '90 T-Bird SC over the
last few hours...trying to find and remove a rocker cover.......
if most everyone states for aircraft usage that throttle bodies and fuel
injection don't need "carb heat' to prevent icing then why does the throttle
body on the TBird have an engine coolant line running thru it right under
the butterfly valve??
