Amphib axles
Amphib axles
I finally got time to put some grease nipples on my amphib axles. I have
heard that MAM is doing it as standard now. I think it was Steve Sloan that
put a plastic tube between the cones so not as much grease has to be used.
Has any one else done this or does MAM new axles have a similar arrangement.
Without this doesn't the grease squirt out by the valve stem of the inner
tube? Also instead of the felt dust seals are there any rubber water
resistance one available?
Also anybody that is running a Subie there has been a big shake up at NSI.
More details can be found at the esubie forum on Yahoo
cheers
Ray
cheers
Ray
Amphib axles
Hey, Ray, I use a set of aluminum cylinders that keep the grease
in the axle bearing area. Julius machined them up for us. I think
Julius did something, too, to keep the water out with seals, but
you'll have to ask him. Mine are just standard ones, and I just
pump more grease in every time I come back from the water.
Did you get your prop fixed?
ray.mason@dcsol.com
Sent: Sunday, August 21, 2005 9:02 PM
Subject: Amphib axles
any rubber water
cheers
Ray
Amphib axles
-> Hi Walter
Was going to fly down last Monday to get it looked at. Filed my flight plan
(crossing US border) phoned custums and got my YVR code, jumped in started it
up and couldn't get the prop out of reverse so had to phone everybody back to
cancell. Ended up taking it off and driving it down. Got it all done which
was real good with what is going down at NSI, and is back on, just need to do
the wheel bearings now. Will give Julius a call tommorrow
-> Hey, Ray, I use a set of aluminum cylinders that keep the grease
-> in the axle bearing area. Julius machined them up for us. I think
-> Julius did something, too, to keep the water out with seals, but
-> you'll have to ask him. Mine are just standard ones, and I just
-> pump more grease in every time I come back from the water.
-> Did you get your prop fixed?
-> Walter
-> > -----Original Message-----
-> > From: mike.davis@dcsol.com
-> > [mailto:mike.davis@dcsol.com]On Behalf Of
-> > ray.mason@dcsol.com
-> > Sent: Sunday, August 21, 2005 9:02 PM
-> > To: rebel-builders@dcsol.com
-> > Subject: Amphib axles
-> > I finally got time to put some grease nipples on my
-> > amphib axles. I have
-> > heard that MAM is doing it as standard now. I think it
-> > was Steve Sloan that
-> > put a plastic tube between the cones so not as much
-> > grease has to be used.
-> > Has any one else done this or does MAM new axles have
-> > a similar arrangement.
-> > Without this doesn't the grease squirt out by the
-> > valve stem of the inner
-> > tube? Also instead of the felt dust seals are there
-> > any rubber water
-> > resistance one available?
-> > Also anybody that is running a Subie there has been a
-> > big shake up at NSI.
-> > More details can be found at the esubie forum on Yahoo
-> > cheers
-> > Ray
-> > List archives located at: https://www.dcsol.com/login
-> Walter
-> > cheers
-> > Ray
Amphib axles
Hi Ray I had a peice of radiator hose the right diameter that I cut slices
DrewI finally got time to put some grease nipples on my amphib axles. I have
cheers
Ray
Amphib axles
Hey Ray,
I used a pvc pipe with the correct od and cut them to length to fit
between the wheel halfs. It was an electrical conduit if I remember right, with a
light schedule too.
Curt N97MR
light schedule too.
Curt N97MR
Amphib axles
Got my axels front and back drilled but need to find a cheap source for the
chrome plated bearings. Napa qouted my 250.00 each cup and bearing, Lindair
190.00, MAM say they don't have them and aircraft spruce says they don't
exist.
-> Hi Ray I had a peice of radiator hose the right diameter that I cut slices
-> off to replace the felt seals. At 08:01 PM 8/21/2005 -0800, you wrote:
-> >I finally got time to put some grease nipples on my amphib axles. I have
-> >heard that MAM is doing it as standard now. I think it was Steve Sloan
that
-> >put a plastic tube between the cones so not as much grease has to be
used.
-> >Has any one else done this or does MAM new axles have a similar
arrangement.
-> >Without this doesn't the grease squirt out by the valve stem of the inner
-> >tube? Also instead of the felt dust seals are there any rubber water
-> >resistance one available?
-> >Also anybody that is running a Subie there has been a big shake up at
NSI.
-> >More details can be found at the esubie forum on Yahoo
-> >cheers
-> >Ray
exist.
that
used.
arrangement.
NSI.
-> >cheers
-> >Ray
Amphib axles
It's because of that price I drilled Howards axles 7 + years ago..... after
the first set didn't make it thru a season! 2nd set is still in there and
rolling fine! Look in the Yellow pages for a bearing supplier that carries
Timken. Here in Ontario it's Canada Bearing. CP's are not usually a stock
item and are hit and miss for availablility. Last time I had to wait over 6
months to get them and they are such a low volume that the CP will be
engaved by hand in front of the part #..
Sent: Friday, August 26, 2005 1:01 AM
Subject: Re: Amphib axles
theGot my axels front and back drilled but need to find a cheap source for
Lindairchrome plated bearings. Napa qouted my 250.00 each cup and bearing,
slices190.00, MAM say they don't have them and aircraft spruce says they don't
exist.
have-> off to replace the felt seals. At 08:01 PM 8/21/2005 -0800, you wrote:
inner-> >heard that MAM is doing it as standard now. I think it was Steve Sloan
that
used.
arrangement.
NSI.
-> >cheers
-> >Ray
Amphib axles
Don't know if they'd have the size you need, but I have always bought high
performance bearings for my model engines from: http://www.bocabearings.com/
They do carry bearings for more than just models.
Sent: Thursday, August 25, 2005 9:01 PM
Lindair
exist.
slices
have
that
used.
arrangement.
inner
NSI.
-> >cheers
-> >Ray
Amphib axles
Also remember though...if you are going the route of saving less than the
weight of a 1/3 tube of grease per wheel by using the "sleeve" (that
probably weighs an equal amount as the grease) you will need to drill some
drain holes in the wheel so they won't hold water and crack from ice
formation in the winter. Filling BOTH wheels completely takes less than
2 -12 ounce tubes of grease. I have not had any problems with the grease
effecting the tube (only the valve stem sees grease), nor a flat tire on
Howard's since they were put on in 1997.
Sent: Friday, August 26, 2005 1:07 AM
afterIt's because of that price I drilled Howards axles 7 + years ago.....
6the first set didn't make it thru a season! 2nd set is still in there and
wrote:months to get them and they are such a low volume that the CP will be
theGot my axels front and back drilled but need to find a cheap source forLindairchrome plated bearings. Napa qouted my 250.00 each cup and bearing,slices190.00, MAM say they don't have them and aircraft spruce says they don't
exist.
-> Hi Ray I had a peice of radiator hose the right diameter that I cut-> off to replace the felt seals. At 08:01 PM 8/21/2005 -0800, you
Sloanhave-> >I finally got time to put some grease nipples on my amphib axles. I-> >heard that MAM is doing it as standard now. I think it was Steve
atinnerthat
used.
arrangement.
-> >Without this doesn't the grease squirt out by the valve stem of the-> >tube? Also instead of the felt dust seals are there any rubber water
NSI.
-> >cheers
-> >Ray
